SOURCE: I have LG TROMM WM1812CW soap leaks out from
For the owners manual go to
http://www.lge.com/us/appliances/washers/index.jsp
and search for your owners manual by part #
SOURCE: how do i clean the filter on an LG Tromm front
The pump filter is accessed via the small hatch at floor level. It can also be behind the kick plate..Unscrew the filter and clean. It may be very badly clogged with whatever is left in pockets. Remember when the filter is removed the water will drain out..Also, check that coins haven't jammed the impeller. Leaning the machine back against the wall will stop the last of the water from draining and will allow better visual inspection...Good luck...Nomess
SOURCE: what does oe mean on the front loader lg tromm and
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
