Question about Harman Kardon AVR 130 Receiver
Hello i have a problem with the AVR 130 Harman Kardon. with optical output does not read me anymore DTS audio of the film. Tried to reset but niente..Aiuto Thank you
cheebster
  • 39 Answers
SOURCE: harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
Posted on Jul 10, 2007
SOURCE: cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Posted on Jun 10, 2008
WolfenHawke
  • 13 Answers
SOURCE: Harman Kardon AVR 135 6.1....AUDIO DELAY???
This model does have a delay function. Programming is on page 19 of the user manual. Go to http://www.harmankardon.com/product_support/interstitial.aspx?sJump=ps&Region=USA&Country=US&Language=ENG select all products, AVR135, and get the owner's guide. If you have trouble with the link, then go to the Harmon Kardon site, and make your way to the support portal and then select all products.
Posted on Nov 26, 2008
  • 308 Answers
SOURCE: AVR amber light will not return to blue after
There is an internal reset switch mounted on the transformer board. Open the unit, look at the boards attached to the transformer, the pushbutton is facing up. Measure the voltage on the 2 pins of the switch. If it is a logic low, the switch is partially shorted. Replace the switch or just cut the jumper wire just below thw switch. When this switch fails, it constantly resets the receiver and stops it from powering up. It does not fix a protection mode problem.
Posted on Mar 04, 2010
  • 119 Answers
SOURCE: I have a harman kardon
We would have the dvd player optical go to the receiver, and the DVD HDMI to the TV.
Posted on Feb 25, 2011
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
My HK AVR-132 doesn't process corectly anymore the signals from optical inputs (DD or DTS 5.1). It happened since I bought a WD TV Live and connected it to the receiver by optical cable. Since then, the...
If you're processing digital audio into the reciver via the TV instead of directly from the source it REALLY originates in (Cable, for example), you are wasting good expensive optical cable and introducing opportunities for digital data problems. I always run the BEST audio and the BEST video directly from their prinmary sources to the BEST electronics that can handle each one. That means they take entitrely different electronic routes from their origins to my eyes and ears.
You need to evaluate what might be happening to the audio on its way (unnecessarily) through the TV to the receiver.
Apr 01, 2011 | Harman Kardon AVR 130 Receiver
I have a harmon kardon avr 120 and a samsung blu ray player.the audio is connected through the optical cable. the receiver however is only playing 2 channel audio. but my direct tv, which is also...
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Jan 06, 2011 | Harman Kardon AVR 120 Receiver
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Dec 05, 2008 | Harman Kardon AVR 130 Receiver
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Harman kardon avr-147
May 07, 2007 | Harman Kardon AVR 240 Receiver
Harman Kardon AVR 130 Receiver Logo
44 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
