Question about Refrigerators
Control panel going on and off and water dispenser going on and off tried unplugging and it stopped for 20 minutes but started again
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
Posted on Aug 06, 2008
MNfisherman
  • 11896 Answers
SOURCE: Water dispenser not working. Ice dispenser works
There should be a water filter inside the water lines to the water spout. This filter could be clogged, or the water lines themselves may still be somewhat frozen and not allowing flow to the dispenser itself.
You can also test the power to the dispensor to make sure it is drawing water. Can you hear the pump trying to pump water to dispenser? The water valve should also be opening. You can test power to the valve that draws in water from the external water lines.
Posted on Nov 25, 2009
aasc
  • 1606 Answers
SOURCE: GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Posted on Dec 09, 2009
Testimonial: "You confirmed what we thought was the problem. Thank you for taking the time to respond!!"
Sea Breeze
  • 4654 Answers
SOURCE: The unit stopped dispensing water, makes clicking nose
If you would like to do this yourself and save the fee of a service tech I ill tell you the motherboard and compressor start components have been affected. Just replacing the board is not always the answer. These refrigerators are sensitive to electrical surge, fan failure, compressor start component failure and eliminating the cause is the best and less expensive way to approach this, I will return later and discuss parts and I do need you to confirm your model is the GSH25JFR, Thanks, Sea Breeze
Posted on Feb 08, 2010
Ice maker and dispenser is not getting water
Make sure "Stop Bar" is all the way down. Check water filter (if applicable. If water filter needs replaced, it can stop water from entering the system). Unplug the fridge or shut power off at fuse box for 20 minutes. After restoring power, If ice maker does not start after a few minutes, Check water inline. (if fridge has been moved, it could have pinched the inline). Check the point of where the inline starts (if possible, disconnect and flush inline. The inline has been known to get clogged at their point of origin coming off of a main water line)
May 15, 2016 | Frigidaire Refrigerators
Car shuts of suddenly while driving. Starts back up after 20 minutes.
When the gas-cap is plugged, you build up vacuum in the gas- tank and cause the gas flow to stop.
Use premium gas only, ETHANOL in the mix is attracting moisture/water which is part of the problems.
Jun 26, 2015 | Cars & Trucks
It won't dispense water and my control panel is lit up and flashing from item to item. Do I need to reset it? My husband pushed a lot of buttons to try to stop the ice maker and ever since then, it w
First, try unplugging the refrigerator for 5 minutes and then plug it back in. If the problem persists, you will need to replace the dispenser control module.
Apr 20, 2014 | Fisher and Paykel Active Smart E522B...
Temperature lights out, water panel in door lights out, no water being dispensed
I assume this refrigerator was working. The sporadic water dispensing is usually a dirty water filter or air in the waterline;but after pulling off the kick board and cleaning,assuming again, the water connector, everything stopped working on the door. At the refrigerator door bottom near the bottom hinge there should be an electrical connector(s) This makes me think you may have dislodged or loosened the connections. This powers everything on the door.
The dispenser may be in "locked".To reset, press and hold lock control for 3 seconds. Another thing to try, if these don't work, is to unplug refrigerator for about 20 seconds, then plug it back in. Electronics sometimes get lost and this will often reset them.
And good luck,
Ron L.
Mar 05, 2014 | GE Profile PSW26P Stainless Steel Side by...
Hi expert, have the GE adora side by side..purchased in '08. I have been having problems for about 2 months. It started with the water not dispensing. I disconnected line..purged and still not working...
this unit has a control boardd that actually controls all the componets/timing sequences on it... g.e has had several issues over the last few years with advertising energy effecient stuff and then recalled some of there monogram units or made it available to customers that they needed the doors replaced in order for them to indeed be enrgy star qualified and then there are the units with control board issues... i would almost be 98% positive you have a control board that has failed... if you unplug it will start over and reset but once reaches timing sequence it will fail again and or relays stick on board/circuit problem... i would purchase a new control board also called main pcb
www.sears.com then hit the parts direct link up top it will ask you to enter the complete model number and you can find the part and price... pretty easy to replace also...just make sure while replacing you have unplugged and avoid excess static electricity around your new circuit board... good luck to you ....
Feb 08, 2011 | GE Adora (DSF25KGTBG) Side by Side...
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
GSH25KGRWW dispenses ice/water all by itself! Heard noise last night, and refrigerator was dispensing ice all over the floor!! Attempted to stop by tapping the lever, but this had no effect; pushed water...
as you explained that by opening the freezer door the problem stopped the problem is: that you have a pinched dispenser wire or, two in the area between the door and, the door opening
these wires are low voltage so they are not going to cause a fire
but, if they touch the cabinet due to a bare wire they will ground and, start running the dispenser.
the door cover needs to be removed and, the problem (usually at the door hinge must be found and, corrected i.e. wire taped, shielded etc.
Sep 14, 2009 | GE GSH25KGRWW Side by Side Refrigerator
I have a rs21dcns fridge freezer. i'm having trouble getting water from the water dispenser and also having trouble setting the temperature control for my fridge.
The water stops flowing from the dispenser when the external water filter needs changing, stick a new filter and it should start working again, it sometimes takes a few minutes to clear the air after the filter change.
Sep 07, 2008 | Samsung Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
