Question about Cell Phones
When i use the charge it came with it want charge then i ues the charge on my other phone and it works good could it be the battery
How do i ues the camera wiyhout a li-ion bayyery
Lithium Batteries are a type of battery, a cleaner charge battery that is made explicitly for electronic devices. They are not that expensive. my camera uses standard batteries.
Apr 24, 2017 | Cameras
Batteries and card are in and will not come on???
Still when nothing works, you should check the battery (batteries) first.
When you use AA or AAA batteries, never use AA manganese (Zinc-Carbon) batteries.
Always use the same batteries. Make sure you charged all batteries. The best to charge them al in the same charger at the same time.
Also check contacts in the battery holder of camera and the contacts of the battery. Nothing is allowed in the holder, then the batteries. Make sure you did not put in a battery the wrong way around.
When you need to clean contacts, only use a dry cloth. Never ues sharp tools in or close to a camera.
Feb 06, 2014 | Cameras
My haier hc-c2030 phone only working with charger without charger phone not working
It is possible that the battery is not charging or retaining the charge while it is charged. So you need to check the voltage on the terminals of the phone to confirm if the contacts are good on the battery. If this is tested to give a good voltage on the battery then the battery is faulty as it fails to charge.
Feb 05, 2011 | Haier Cell Phones
It runs low battery every 30 mins
problem can be solved.Does the phone get hot?, If yes,it is a board problem and will definitely run the battery down.
But i if no, that means the cell of the battery is very weak and can power the phone for too long, that is why it goes off.
You need to get new battery.And make sure after purchasing a new battery, you charge the battery for longer hours until it shows 100 percent charged before using it, otherwise the cell of the battery will not work properly.
Have a nice day.
Mar 19, 2010 | Nokia N70 Cellular Phone
Started my 2003 Chevrolet Tahoe this afternoon and the battery started flashing, dash said battery not charging, then brakes started messing up (felt like they were puslating)..dash then read battery not...
check ue alternator to see if its charging ur battery to check this start car and disconnect pos cable from battery if it shuts off its ur alternator
Feb 27, 2010 | 2003 Chevrolet Tahoe
JVC GY-HD110U
discharge your batt. fully. charge your batt. on 3phase current. dont remove in middle, give time for your batt. to charge fully
ues JVC original batt.
Jun 18, 2009 | JVC GY-HD110U Camcorder
Installation of voice call recorder
Dear All
I would appreciate if you give me code of l 700 samsung !
The question is ? somebody gives me a code of l 700 , when i applied my mobile restart, Now three days past but my battery showing full , some time my mobile off , when a charge again cell showing battery full
May 02, 2009 | Samsung SGH-L700 Cell Phone
Unable to charge
Same problem here but phone is 14 mo old. Just stopped charging even though it says it is. Got new battery, same thing. Charged battery in different phone and was fine. swapped and it works. so... phone is bad somehow.
Apr 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Sep 23, 2007 | LG WM1814CW Front Load Washer
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
