Basic set up
Make TV work properly
  • kakima Dec 04, 2016
    Hi Dana Brehm, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
How to get a hdtv working without cable box
The set will need the original remote for even basic things, and it if HD will not work with no signal connected to it, need to put gas in the car and need to have signal connected to the set properly.
Dec 23, 2012 | Sylvania Televison & Video
No power no power light. working ok last night. its plugged in to an outlet that has other appliances in it and they are working fine. already changed power cord. please advise
You need to go inside the set and check out the power supply module next. Please read my guide to get basic understanding.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 22, 2010 | Proscan 26LA30Q 26 in. LCD Television
My 32 inch samsung tv the red light in front is on but nothing happens and the remote does not work as well. We took the board out, what needs to be replaced.
You need to do indepth inspection and voltage checking first to narrow down the problem, but you need to get somne basic on how LCD TV works first.
Oct 22, 2010 | Samsung LN32A330 32 in. LCD TV
I own a PANASONIC TC-32LX85 32″ TV I read the info that you posted about the POWER SUPPLY BOARD TNPA4484 but I can find the capacitor marked 3300uf 10V, and all of them look like new... they...
Not all power supply used 3300uf/10v, it can have many many values, he was using generic term for typical value.
You should get the service manual for this TV first. You then need to do some voltage checking. Please read and undertand some basic how the LCD flat panel TV works so you will get some unsderstbding how it works.
Oct 19, 2010 | Televison & Video
Wont turn on. it is plugged in properly and remote has new batteries and lights up. Programmed to operate TV. No red pilot light illuminates on the TV.
If the front panel does not even light up, then you do not enevn has the standby 5vdc working at all. Power supply module will be the first place to look.
Oct 02, 2010 | Samsung LN55B650 55 in. LCD HDTV
My tv just stopped working over night. It will not turn on.
Power supply module will be the first place to look, please read my guide to get basic understanding of how LCD flat panel works.
Aug 20, 2010 | Insignia LCDTV26 26 in. Television
I pluged the cable line from the cable box into the"ant" section of the tv and it does not work? hooked RCA cables up and it work
Either the connector to the cable box or to the TV may not be hooked up properly.I am pretty sure you would have tried those over and over so either there is a problem with the cable box,or the antenna input connection on the TV.At least try disconnecting the cable from the box straight into your TV and check it,you should at least get basic cable stations as long as your cable is activated at least.If you do get basic cable,then the cable box is bad.If you do not get basic cable,either the cable is deactivated or the box is bad.If you are not sure how to get to cable TV options in your TV,you can try autoscan or please let me know and I will reply ASAP.Good luck!
Aug 05, 2010 | Panasonic Televison & Video
My Direct TV RC64R remote won't work
Yes 10030 is the code. Many Thanks to the Guest.
Sep 29, 2008 | Televison & Video
Missing channels
Make sure that the set is in the proper mode. There are Air and Cable settings.
Dan
Jul 23, 2008 | Dell W3201C 32 in. LCD Television
Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Oct 17, 2007 | Philips 36PT41B TV
Televison & Video Logo
Top Televison & Video Experts
