Question about Panasonic Televison & Video
My 2010 Panasonic TV when I turn it on it goes into a self check mode, then freezes and nothing not even the remote will work
It's not a smart tv
    Top Expert:
  • Panasonic Master
  • 75,471 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Dec 04, 2016
Remote sensor not working on my Vizio Smart TV
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Viewing it in "Mosaic" or "Sidebar" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 07, 2014 | Vizio E-Series - 50" Class 50" Diag. - LED...
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Panasonic viera TH50PZ700B 4yrs old. will turn on and begin auto search however does not find channels, sky aerial cables connected. the screen goes to customer id but as soon as a button on the remote...
Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Go into the tv menu go to PICTURE to go down to do a resetting to the tv Tuner signal board.Tries scanning for channels again.The tv should be work again,if it still have the same result.The tv main board,the tv Tuner signal board is bad.Can u do some mechanicals work like take things aparts and putting it back together again?Yes?Try website like Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 15, 2011 | Panasonic VIERA TH-65PZ700A 65 in. Plasma...
Panasonic appears to be stuck in self check mode?? have tried turning television off at wall and leaving for an hour but still it does a scan then goes to a screen where it says self check complete. remote...
I had this issue twice and solved it once. The first time I had it I unplugged the TV and switched the batteries in my universal remote. By some miracle I was able to click ok and my TV worked again. However, I currently have the same issue but the solution I used to first time will not work. Any suggestions on how I can fix my TV?
Apr 15, 2011 | Panasonic Televison & Video
Why does your PANASONIC tv ask for a password?
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
or
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip
Dec 30, 2010 | Panasonic (TH-50PZ700U) Television
Cant turn off panasonic PIP
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
Jun 12, 2008 | Panasonic CT-36D32 36" TV
No picture but sound on panasonic plasma
Unplug the TV and disconnect any HDMI cables to the set. If the issue goes away there is a possibility that your HDMI source is causing the problem. Anything on the HDMI can cause odd problems with the TV since the serial data and serail clock lines are routed on HDMI. Those are the 2 commmunication lines used throught the TV for operation so anything HDMI that might load down one of those can cause issues.
Mar 07, 2008 | Televison & Video
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
Vcr freeze frames tv programs when turned on
No nO NO the cable out from the cable box goes to the input of the VCR and the VCR output goes to the TV connection. Good Luck
Jun 05, 2007 | Panasonic PV-V4525 VHS VCR
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Televison & Video Logo
32 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
