Question about KTM 2013 125 DUKE
The check engine light came on my KTM duke 125 after I was driving it in the rain what should I do?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • KTM Master
  • 47,272 Answers
Hi, Peleg it should be noted that the reasons your check engine light constant or flashing, will or will not start, turns over or not conditions varies from the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work or event IE: adding accessories, electrical curiosity/adventures, laying bike down/crashes, rainstorms/bike washings just before EFI light issues started can be significant hints/aids into tracking down the gremlin, also carry the appropriate jumper wire to access fault codes to reduce the risk of being stranded or towed, that being said the usual suspects are:
1. Faulty Fuel Pump, fuse or system relay switch.
2. Battery starting to fail due to old age/damage, perform a load test.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
5. Broken wire or worn insulation exposing wire to a ground situation especially inside wire harness at tight bends around fairing brackets, under dash panels, under fuel tanks over cylinder heads etc. Many harnesses are open on the ends that will allow water to enter and accumulate at v-bends.
6. Check for generated fault codes.
Dielectric grease and contact cleaner are your best friends for wire/cable/harness connectors, look for corroded, broken, or loose pins/sockets.
For more information about your issue please visit the websites below. Good luck and have a nice day.
Ktm duke 125 Check Engine
https://drive.google.com/file/d/0B-UgQx8CVp8JemN0Z2FRQnFQLU0/view
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 125 DUKE EU Owner Manual KTM DUKE 125 200 2012 Workshop Repair Manual
Posted on Dec 05, 2016
Hi I have a 2013 Ktm duke 125 the stator winding broke not sure why after having it rewired I fitted unit onto bike when I tried to start it just has a winning sound and will not turn moto any ideas
Hi, Anonymous for this situation I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.motogelnar.cz/manual/KTM/KTM125-200_1999-2003ServiceManual.pdf
KTM 125 Duke 2013
KTM Wikipedia
Apr 15, 2017 | KTM 2013 125 DUKE
The ignition button wont work
Hi, Ryan before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
Ktm Duke 125 Will Not Start
HELP Starting problem KTM Duke 125
http://www.ktm.com/globalassets/product-manuals-pim-data/dok_bike_bed_13_3211963_en_om__sen__aepi__v1.pdf
Apr 10, 2017 | KTM 2013 125 DUKE
Ktm 125 duke won't start when turn ignation on there is just a click
Sounds like you just have a defective battery, pull the battery and have it tested.
Aug 17, 2016 | KTM 2013 125 DUKE
I turned on duke 200 and as soon as i removed the stand! The display went off. Since then, nothing is shown on the display and the bike does bot even start. Just wondering what could be the fault?
Hi, Malkeet and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below Good luck and have nice a day.
KTM Duke 200 refuses to start What do you think can be the problem
What to do When Your Motorcycle Won Start
2012 Duke 125 200 Repair Manual pdf
Apr 17, 2016 | Motorcycles
Problem check engine
Have you checked the engine? Coolant, oil etc. Call your KTM specialist because the electronics are complex.
Dec 05, 2014 | KTM 2013 200 DUKE
KTM 125 Duke 2011 mil light blinking two long and three short.
You are SOL! Have to take it to the dealer. KTM has not given a list of the fault codes for that bike. That bike also has alot of problems with the computer and going into safe mode.
Apr 06, 2014 | 1998 KTM Duke
KTM Duke 125: dashboard shows "Low oil pressure" but the moto is just back from the garage, and he has certainly enough oil.
Since it was just worked on ... take it back and find out what the problem is. Could be a disconnected or faulty sensor. In any event, since you took it to be repaired, and paid for it, get it repaired. Don't run the bike until this is resolved. Low pressure is DEADLY to a engine.
Feb 07, 2013 | KTM Motorcycles
When is duke 125cc will arive in nepal?how much will it cost
hi check here
http://a2znews.net/ktm-duke-125-bike-review-features-price-price-price-in-india-colors-specifications-mileage-a2znews-net/2010
Nov 26, 2010 | kawasaki Full Suspension Mountain Bike Men
2008 KTM 990 Super Duke added Leo Vince slip on's now bike will not start
Hi, Erideree young ECM's can be very picky about strangers wanting to play with her children, it should be noted that the reasons your FI light stays on constantly or flashes and your bike will or will not start and may turn over or not, these conditions will vary from bike to bike depending on the year, make, and model and you should always refer to your owners/service manual for proper diagnostic procedures. It should also be noted that any type of prior work done to the bike or an abnormal event occurrence IE: adding accessories, electrical curiosity/adventures, laying the bike down/crashes, rain storms/bike washings just before FI light issues started can be significant hints/aids into tracking down the gremlin. The newer the bike the more sensitive the ECM becomes and will not let the bike start when aftermarket accessories have been installed without being reprogrammed. That being said the usual suspects are:
3. A discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty safety switches/sensors: run/off, ignition, clutch lever, neutral, side stand, tip over, fuel, and or their connections.
6. Installation of aftermarket accessories ie. exhaust systems, mufflers, air cleaners, fuel tuners, electrical component etc.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
KTM 2003 950 Adventure Repair Manual
https://www.partsfish.com/page/oem-parts-for-ktm
KTM 990 SUPER DUKE 990 SUPER DUKE Owner Manual
KTM 990 Super Duke
KTM Wikipedia
Nov 03, 2017 | 2008 KTM 990 Super duke
Duke 2 loss of power when engine under load
Is the bike at stock condition?
Check the carb and the charging system.
You should measure 13,5-14V at your battery in 3000rpm with your high beams on.
May 31, 2009 | 2004 KTM 640 Duke 2
KTM 2013 125 DUKE Logo
2,001 people viewed this question
Top KTM Hunting Experts
mark moore
mark moore
Level 1 Expert
Dan Apthorp
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Are you a KTM Hunting Expert? Answer questions, earn points and help others
