Question about Staples Tools & Hardware - Others
Loading T-25 staples into Mastercraft 4 in 1 stapler. I can't push the holder all the way in. They're catching
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
  • 1388 Answers
SOURCE: driving pin won't reset
The check valve is what causes the pin/driver to return to top of cylinder. To check if it is in place, remove the cylinder from the gun and look for an oring/band installed on a groove. This groove should have vent holes drilled thru the cyl. Holes should be clean. Any oring or rubber band can be used here. Just tight enough to stay in place. Other things to check:
Pin/driver should fit snuglly enough to hold it's own weight in cylinder. If your gun uses a plastic ring, it may be replaced with a rubber oring. Just make sure that the piston travels freely but holds its wieght.
There should be a bumper and a washer in the lower part of the gun. The bumper should not have any cuts or missing pieces and the washer should fit snuggly around the driver blade to prevent air from leaking down thru bottom of gun. If air is leaking down thru bottom, there is less pressure to push driver up. Email if you have more questions, good luck with your repair.
Posted on Feb 23, 2009
  • 10865 Answers
SOURCE: loading staples
Hi Sharon. It is absolutely essential that you get the staples designed for this stapler. These are Powershot 5700 staples.
please mark this answer as a fixya! thanks.
Posted on Mar 12, 2009
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
Load staples in et50 arrow stapler
It will probably have a release at the bottom rear of the stapler. Just push the release in and down to release the rod/spring assembly (the release catch may be silver in color). Drop in a stick of staples the reinsert the rod/spring and reengage the release.
Dec 12, 2014 | Arrow Tools & Hardware - Others
Loading staples
Powershot Pro (Model 8000) Loading staples is pretty much what you would guess,
EXCEPT that releasing the catch takes a very strong pull, or it won't budge at all. Grasp the black plastic catch at the rear of the stapler base, pull very hard (probably 5lbs or more) and the catch will move about 1/4" away from the stapler ("down" if you think of the stapler in its usual orientation.) You can then slide the catch and the spring mechanism "backwards" leaving room to insert staples or brads. (Note, "T-50" staples and brads should fit. If loading brads, they go along the side of the magazine which is closest to the "staples remaining" window.)
Oct 10, 2011 | Arrow 8000 Power Shot Pro Staple & Nail...
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Just bought and tried to load my Swingline Smart Touch low force stapler. Don't know how to get it opened
I have one of these models. Just push the gray lock mechanism at the end of the stapler and the loading magazine will pop out. The chrome plated magazine opens towrds the front....it slides forward and backwards.
Jun 17, 2011 | Office Equipment & Supplies
How do you add staples to a swingline 8784x stapler
You need to remove the black cap at the back of the stapler, then use a screwdriver to press down on a lever inside the stapler. The stapler holder will pop out at the front, then pull it further out and load with staples. May be an easier way, but this what worked for me.
May 20, 2011 | Office Equipment & Supplies
How do you load new staples?
Find the button on the bottom of the stapler's back edge. Push the button in and down. Pull out the bar that pushes the staples into place. Slide in a row of staples with the points facing down. Push the bar back and lock it into place
Feb 20, 2011 | Arrow CHROME STAPLE GUN ARROW IND....
How do i load the staple gun?
1 Hold stapler upside down.
2. Release black plastic catch at rear and pull out.
3. Drop staples into bottom of gun, with open side up.
4. Push black plastic catch closed and latched.
wallyp
Oct 30, 2010 | Stanley Bostitch Pc4000oc2 Outward Clinch...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Tools & Hardware - Others Logo
182 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
