Question about Desa International (R165DT) Utility Heater
Need regulator for computor board #st vu bir08 400b m 31 call 207-798-1119 please
  • lsg2111 May 11, 2010
    What is the model number of your heater? If it is a Reddy Heater the board does not have replaceable parts it comes as a complete board or assembly.
  • 188 Answers
I sugest yo contact Master Parts. They may have the part available you need. You can contact me at 800-446-1446 or online at www.masterparts.net . I hope this helps...
Posted on Aug 28, 2009
2008 Triumph Sprint ST cuts out for no reason
Hi, Morne and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
955 Sprint cutting out
engine cutting out Problem Solving Tech Forums Messageboard Triumph Torque
Triumph Sprint ST Service Manual
http://www.triumphestore.com/
Triumph Sprint ST Owner Handbook Manual
Jun 21, 2017 | 2008 Triumph Sprint ST
Thank you for replying on the computor boxs can you please tell me why does the alternator bench do that let the computor boxs burn?
having the alternator bench tested is to ensure that the alternator is checked for voltage regulation and out put current
it tests for ac current from failed rectifiers with out the problem of having the faults in the electronic system interfering with the tests
after the tests prove that the alternator is good then the accredited auto electrician can check the ECM
they are much better at the job than a mechanic and will find the reason for your problem
Nov 20, 2015 | Cars & Trucks
Philips 32" lcdtv after 2 hours st by position
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 22, 2015 | Philips Televison & Video
How do i connect to my hdmi tv
You need to see if your computer has HDMI or DVI connectors, without them its impossible.
Mar 05, 2011 | ST-Lab PC Laptop Mac Computor to HDMI TV...
2004 Skyteam ST 125 Y fuel and vacuum line diagram
Hi, Steven for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Skyteam, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2004 Skyteam ST 125 fuel and vacuum line diagram Google Search
Fuel and Vac Line Tutorial
Suzuki RM 125 Owner Service Manual
http://www.skyteamparts.com/store/st/125cc
http://mybikemanuals.com/suzuki
Dec 09, 2017 | 2004 Skyteam ST 125 Y
1994 t-bird tomuch fuel consumtion they tell me
better check the fuel pressure regulator on the rail, ive seem them leak into the vacuum hose that connects to the intake, then check for leaking injectors, good luck
Nov 09, 2009 | 1994 Ford Thunderbird
OVER CHARGING
check the wiring of the voltage regulator.... if it's correct... that regulator is likely defective
Mar 21, 2009 | 2004 Skyteam ST 200
Desa International (R165DT) Utility Heater Logo
47 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
