Question about Dishwashers
Lamona HJA 8630 dishwasher - Water seems to be dripping down from the hot air vent once the dishwasher has been turned off. Resulting in the dishwasher flooding. What could be causing this?
Water seems to be dripping down from the hot air vent once the cycle has finished and the dishwasher has been turned off. It then collects at the bottom and if the water to the dishwasher is not turned off it floods the dishwasher.
SOURCE: Frigidaire Dishwasher Problem
Water could be draining back in to the unit drom the disposal as well. Need to have a loop under the kitchen sink as well.
Posted on Aug 03, 2007
  • 1073 Answers
SOURCE: Problem with Kenmore dishwasher model# 15762000
replace the water inlet valve, something is inside the valve holding it open, dirt small grain of sand, ect.
Posted on Apr 10, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Posted on Sep 21, 2008
  • 744 Answers
SOURCE: Water flooding onto floor when running.
The most common cause of this is a loose clamp on the pump discharge hose. It could also be a cracked hose, the hose came off (again, loose clamp). Check both ends - where the hose connects to the dishwasher AND where it connects to the sink drain.
Another possible cause is a bad pump seal, although this is less common, and usually open happens when the dishwasher is pretty old.
Posted on Jan 05, 2010
Testimonial: "Very quick and easy to follow instructions. Thanks."
  • 70 Answers
SOURCE: Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Posted on Jun 30, 2010
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
Howdens dishwasher hja8362
The water in the machine is normal there is nearly always 1/2 a lit to a lit of water when a load is finished. Also if you dishwasher is out of warranty there Re a few things you can do one go buy a $20 voltmeter and unscrew the face plate and see if anything is lose mine hade a wire come lose and made the hole thing misbehave.
Jan 26, 2014 | Dishwashers
Lamona hja8630
How do I remove the integrated door af a lamona hja 8630
Jan 01, 2014 | Dishwashers
User manual for lamona dishwasher HJA 8630
Hi my salt level indecator light stays on even when I have filled it with salt! please help anyone
Thanks Rose
Dec 24, 2010 | Dishwashers
Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Feb 21, 2010 | Dishwashers
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Jun 25, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bosch SHU4322 Dishwasher leaks in the door
Detergent dispenser gasket or faulty air vent.
Feb 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Door leaks
This dishwasher has a vent at the bottom left of the door that blows out hot moist air during the drying cycle. Are you sure that you are not getting condensation build up from this vented air that is dripping on your floor?
Dec 29, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
