Question about Toro Garden
My Toro 724 qxe runs erratic up and down whats the problem.
2 Suggested Answers
  • 211 Answers
SOURCE: toro gas leaf blower erratic engine performance
hi
change the sparkplug or seals.
bye
Posted on Oct 07, 2009
I have a Toro 724 snow blower model 38050. It runs great. Everything works and turns. When I engage the drive and or the auger. It kills the engine like when I shut off the key. If I hold the safety...
Sounds like the safety switch is bad or needs resetting. I had a lawn tractor that did that and I disconnected the safety switch. I know you should not do this but I did not want to put more money into this machine. It does work ok without it.
Feb 18, 2018 | Toro Garden
Old, old toro 724-z zero turn lawn mower drive belt???
Seen some on ebay? do not know if suitable thoguh?
May 03, 2017 | Toro Garden
Back fires when running at high speeds
if its older valves may be getting worn
but before you check valves
clean carb change the plug and put fresh gas in it
Feb 06, 2014 | Toro Snow Blowers. Power Max 724 OE 24 in....
Toro gas leaf blower erratic engine performance
hi
bye
Oct 04, 2009 | Garden
Toro 724 snowblower won't start
One of two things will cause this. Either your piston rings have fried and your piston is stuck. The bearing on the flywheel is bad. Or actually one of thing, the crank shaft has broken. You willl need to take the motor apart all the way and see what is going on. If you take the flywheel off try to turn it by hand and see if you can turn it that wy. You also can try easier to check for first symptom is to make sure you are not in vapor lock. Remove the spark plug, turn unit upside down and see if you can get the motor to turn, if you can then replace the spark plug and it will start up. You can getvapor lock by running it low on fuel or the wrong fuel or running it to rich
Feb 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
67 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
