Question about HP PSC 750 All-In-One InkJet Printer
I put one new color cartridge n it says error in color cartridge wat to do
    Scholar:
  • 151 Answers
You may not have got the right cartridge for the printer, it may look the same but it might not be the right number for your printer.
Posted on Jul 20, 2009
I own a canon iP1300 printer and just bought a new canon pg- 40 black cartridge but its not being recognized by the printer, wat do i do
Can be a problem regarding the cartridge. What is the status of the color cartridge. Take a printout with the color cartridge alone. If no problem found get your PG40 cartridge replaced. One thing to be noted is that the printer always needs the color cartridge installed. Printer can work with color cartridge alone. But will not work without a color cartridge
Apr 09, 2011 | Canon PIXMA iP1300 Printer
I am getting the following error message: Black/photo cartridge missing
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 5 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 5 color cartridge.
Close the printer. It should print an alignment page. Any error messages?
Black cartridge = black side(left side) color cartridge = color side(right side)
Photo cartridge = black side(left side) color cartridge = color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
If these ink cartridges are new, then take them to the place of purchase for a refund or replacements. If they're old, then try purchasing a new Dell Series 5 ink cartridge.
Rick
Mar 06, 2011 | Dell 924 All-in-One InkJet Printer
Printer flashes error "replace color cartridge"
Try unplugging the machine and removing all the ink cartridges.
Now plug the power back in. Wait a minute or two and then reinsert the ink cartridges.
If you get the same message, the machine's ink sensors are probably finished.
Thanks,
Pat
Nov 08, 2010 | HP PhotoSmart 1115 InkJet Printer
Put in a new colr cartridge and the printer says it is missin
Please try installing the old color cartridge in the printer and let me know whether you get the same error message. If you dont get any error message then the problem might be with the new color cartridge.
Oct 17, 2009 | Office Equipment & Supplies
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
Mar 27, 2008 | Lexmark X2500 All-In-One Printer
Color Cartridge Error
if u r sure about the catrige then its a problem with the carriage unit ,in which the catridge seats,it has to be replaced.
thnx N
Feb 01, 2008 | HP Officejet J5780 All-In-One InkJet...
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
103 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
