Question about Lakewood Heating & Cooling
Lakewood heater model 530 wiring diagram - Lakewood Heating & Cooling
    Top Expert:
  • Lakewood Master
  • 41,774 Answers
Request the diagram from Lakewood.
Posted on Dec 05, 2016
  • 34 Answers
SOURCE: i need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
Natemane
SOURCE: ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Posted on Jan 01, 2010
wilsodfarm
  • 986 Answers
SOURCE: Lakewood Model 7101 - Need to drain the oil to dispose of it
I just drill a hole and I put old oil in my used motor oil
Posted on Jan 13, 2010
SOURCE: wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Posted on Dec 11, 2010
  • 3382 Answers
SOURCE: WHERE CAN I PURCHASE A NEW SWITCH FOR A LAKEWOOD HEAD HEATER, MODEL NO.7000/A
Try the manafacturer or your local appliance parts store.
Posted on Dec 19, 2014
Are you telling I can't get a wiring diagram for LAKQTV-22 heater.
Hello -
I have looked for a wiring diagram for your heater. I even checked the web site of the manuafacturer, Lakewood Engineering & Manufacturing Co., Chicago, Illinois with no luck.
In fact, it seems the company no longer manufactures any heaters.
Jan 15, 2018 | Heating & Cooling
My Lakewood heater turns on but will not produce heat. Any ideas as to what is wrong????
Same symptom on my oil-filled Lakewood model 5500. Used an ohmmeter to check it out and found that 1) the thermostat is defective and potentially a fire hazard due to intermittent operation. 2) Then I learned of reports about some Lakewood oil-filled heaters squirting hot oil and injuring people, and 3) the manufacturer subsequently going out of business. Three strikes and you're out.
I cut off my heater's power cord and threw the whole thing away, and recommend others to do the same.
Feb 07, 2011 | Lakewood Oil-Filled Electric Radiator...
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Need wiring for on-off switch
Hi Joe. Typically the switch interrupts the hot wire, which is black. Therefore, two black wires are connected to the two screws on the switch. Look in the area where you see the one black wire and you should find a second black wire. Connect each of the to the switch and you will be switching [controlling] the hot [black] wire.
Dec 10, 2009 | Lakewood 7101 Oil Filled Radiator Heater
I need a wiring diagram for a lakewood 5500
Feb 13, 2009 | Lakewood Oil-Filled Electric Radiator...
Aug 27, 2008 | Lakewood Heating & Cooling
Heating & Cooling Logo
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
