You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Activate and connect to a WLAN 1.In range of WLAN network, access an application or menu that needs a wireless connection. 2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi. 3.Press <Menu> → Turn On Wi-Fi. The device will display available WLAN connections. 4.Select a network profile from the list. The device will attempt to connect to the WLAN. 5.Select a network type and press <Next>. 6.Enter a pre-shared key for WLAN and press <Next> or <Finish>. 7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN 1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi. 2.Select New... 3.Enter a network name, configure connection settings, and press <Next>. 4.Enter network authentication settings and press <Next>. 5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary). 6.When you are finished, press <Finish>.
Dear Meghna
you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client
this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup
thankyou and take care
Gagan Gupta
Blu-ray players are getting more internet capable and any player made 2010 or later is probably going to have wi-fi or wireless internet connectivity. However not all players are the same. Some Blu-ray players are wi-fi ready while others are wi-fi built-in. What's the difference? Wi-Fi ready players need an extra part called a dongle or adapter stick to make them work with your wireless router and not just any adapter, typically only the one the player's manufacturer offers. Usually this will cost you an extra $80. But Wi-Fi built-in players already have the adapter in them and are ready to go without adding a part. Be sure to check if the player is Wi-Fi built-in, as this is what you want for wireless connectivity.
Use the Alexa app to update the Wi-Fi settings for your Echo device. Echo devices connect to dual-band Wi-Fi (2.4 GHz / 5 GHz) networks that use the 802.11a ...
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
How do I delete that thermostat from my Lyric app? If you've moved and ... How do I change the email address I use to manage my Lyric? If you already have a ...Missing: programmable ‎accurate
HoneywellThe Wi-Fi 7-Day Programmable Thermostat is designed for the way you live ...Features such as Smart Response and precision temperature accuracy bring ... your home heating and cooling system, and then remove your existing thermostat. .... Whileconnecting to Wi-Fi, my model RTH6580WF or TH6320WF thermostat is ...
Samsung ElectronicsFAQ00061225 I cannot connect to Wi-Fi® on my Samsung device. ... On the mobiledevice, attempt to connect to the Wi-Fi network. If you are not able to connect ...
Your cellular carrier can provide you with a "signal booster" device that can repeat and boost a cellular signal you already get in your house. For example, if you consistently have one bar of coverage but no more at home, a booster can take that one bar and turn it into more bars. If you have one or two bars of coverage near a window but no coverage elsewhere in your home, a booster near that window can capture the signal and boost it, providing a strong signal throughout the rest of your home.
Some carriers offer such devices very inexpensively - $50 or maybe even free - especially if you're in an area where they know they know they have poor coverage. T-Mobile now offers such boosters for only a $25 deposit, which you can get back just by returning the booster to them.
Contact your carrier - or look at their website - to see just what they'll offer you and for how much.
Femtocells / Microcells
A femtocell - or "microcell" - is a small, low-power cellular base station that connects to the cellular network via your broadband Internet connection. Essentially, it's a small cellular signal tower that will provide a signal in and near your home, connecting to the larger mobile network over your Internet connection. This makes it ideal for situations where you don't even have a signal bar of coverage you can boost at home. The only "catch" is that your Internet connection must have a high enough download speed. Different carriers require different minimum speeds, but you should be fine as long as you have a solid broadband connection.
Ask your cellular carrier if they offer this sort of product and find out how much it will cost you. As with boosters and repeaters, a femtocell may be available at a steep discount from your carrier in areas they know they have poor cellular service.
You can also buy them easily on Amazon or almost any decent tech store - for instance the one pictured below works for AT&T and supports LTE (though it is a bit pricey), or you can get one that supports Verizon, T-Mobile, AT&T, Sprint, Cricket, and many others, but you won't get LTE support. Of course, since you likely have Wi-Fi in your house, LTE isn't really a big deal and the 3G will work just fine for calls and texts.
Editor's Note: For the official How-To Geek office we got a Samsung microcell device directly through Verizon, which wasn't cheap, and doesn't work all that well. And since it only works for Verizon, any of the people who come by who use other carriers have zero signal, which is really annoying. If we could do it over again, we'd have started with this zBoost microcell that supports virtually every cell provider and has many different models and options to choose from depending on the size of the house. They even have an optional antenna you can install on your roof to give cell coverage everywhere around your house. It's the best choice, and cheaper than most carriers will offer you.
Wi-Fi Calling and SMS
Wi-Fi calling is a feature you might remember from some years ago, but it's coming back with a vengeance. At the moment, in the US, only T-Mobile offers Wi-Fi calling for both Android phones and the iPhone. Sprint only offers Wi-Fi calling for select Android phones. AT&T and Verizon have announced plans to activate Wi-Fi calling in 2015.
Essentially, WI-Fi calling allows your smartphone to receive and place calls and communicate via text messages over a Wi-Fi network. Your home probably has Wi-Fi, so Wi-FI calling will let you use your existing wireless router instead of needing a new, specialized device. You can just improve your Wi-Fi signal strength, and all your devices will benefit!
Wi-Fi calling works transparently. When your phone is on Wi-Fi and has a poor cellular signal, it will connect to the Wi-Fi network and your phone calls and text will be sent and arrive over the Wi-Fi network. When you leave the Wi-Fi network, your phones and calls will be sent over the cellular network as usual. This is all designed to hand-off automatically, so you could start a phone call on your Wi-Fi network and your phone would automatically hand off to the cellular network as you walk out the door, with no interruptions.
WI-FI calling will also work on other WI-Fi networks, so it's helpful if you ever end up in another place where you have a poor cellular signal but have Wi-Fi. To use this, you'll need to ensure your phone has Wi-Fi calling support and that it's enabled. Android phones from T-Mobile and Sprint will often include this feature, so look up how to enable it on your specific model of Android phone.
The iPhone 6 has built-in Wi-Fi calling, although it currently only functions on T-Mobile. AT&T and Verizon plan to support it in 2015. To enable this feature on an iPhone, open the Settings screen, tap Phone, tap Wi-Fi Calling, and activate it.
WI-Fi calling seems to be the future goal the industry - T-Mobile, especially - is pushing towards. With Wi-Fi calling integrated into your phone, you don't need to buy a specialized device. Your home Wi-Fi router works. And, when you go somewhere else where you have a poor signal, all they need is a Wi-Fi network and you'll be able to get a phone calls and SMS messages through it.
Image Credit: Carl Lender on Flickr, Nan Palmero on Flickr, Wesley Fryer on Flickr
Hello Ricardo.
How are You? I Guess you need to
1- Check your wi-fi router model.
2- Check your wi-fi settings.
also please check how many devices are connected to your wi-fi at same time. because some routers can only support upto 5 device. you can check this in the settings and also routers manual.
