Question about Ovens
I received my oven for Christmas last year. I use it a lot but now the elements don't come on. The lights come on and timer works just no heat
  • 492 Answers
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Posted on Apr 30, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
  • 77 Answers
SOURCE: Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Posted on Nov 28, 2009
  • 187 Answers
SOURCE: bake element does not heat up
This would be a good candidate, but not necessarily an absolute. Selector switches, loose wires, fuses, and a few other sundries could also be the cuprit. Make sure that the new element that was installed is the correct one for your model. I am assuming that the element was replaced?
If not, by all means, check the element. Elements only last a few years. Just because the plug it plugs into has current, it doesn't mean that the element itself is any good. By far, a burned out element is the most common, easily fixed failures.
Unplug or shut the appliance off at the breaker. Pull the element and visually examine for burnt or rough spots. The elements either pull directly from the housing, or are held in place with a few screws. Bad elements sometimes look totally normal.
If the bottom and top elements are the same( they usually are) a simple check would be taking out the broiler element and then swapping for the bake element. If the broiler element works in the bake position, buy a new element and ask for a refund for the service call.
I can't understand why the service person did not pull the unit and check voltage in the control before making an absolute diagnosis. The circuit board is usually well over 100.00. The unit also sometimes comes with a diagnostic feature that homeowners/techs can use to test the "ERC" without even taking it out of the range.
If you have your owners manual, check the trouble shoot section. If not, Sears has some manuals and repair help/parts online, and Whirlpool is among the best companies in terms of customer supports. I don't know your model, so I can't be too specific with advice. The link for Whirpool has a search engine you can use for your exact model. This link is for most newer models. Among other online resources, Repair Clinic" has parts that you can order online, and they also have diagrams that can help out significantly if you do change the unit out yourself. If it is something cheap like an element, it is helpful to go to an appliance store where you can return the unit a little easier. Thanks for your question, please leave comments if you need further advice.
Posted on Dec 14, 2009
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Why does my Oven not heat up ?
Did you check to see if the element is receiving power? Is element open?
Feb 25, 2016 | De Dietrich Ovens
No heat from oven although fan and light are both working
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Belling XOU270 / XOU271 Electric Single...
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
The oven isn't heating up.
Hi ,and welcome to fixya.
Make sure that the timer is set to manual, and not on auto, or the oven will not work.
If it is a fan assisted oven and the fan is working, then you wiil probably find that the oven element has gone, you will find this located behind a removable cover at the rear of the oven.
It is a very straight forward job to replace same.
Plz rate my solution.
Thanks, and a merry xmas.
Dec 22, 2008 | Ovens
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
