Question about Car Audio & Video
AM not working at all but FM is fine what is up?
  • Brett Duxbury
    Brett Duxbury Dec 04, 2016
    Hi Linda Granowetter, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    how is the aerial ?
    is cable plugged into radio ?
FM radio does not work on receiver
Unfortunatly it sounds like the FM tuner pack is faulty and only replacement can cure it.
Jan 12, 2013 | Car Audio & Video
Wife was driving our 1999 galant and the FM radio stopped working. The AM and CD works fine. Is there a problem with the antenna?
if am is working fine, you probably have a bad fm tuner. it is not going to be the antenna.
Aug 02, 2010 | Car Audio & Video
No am radio but fm works fine
I don't know why you need AM, but that's not the issue.
If you have FM and HEAR it ok, then everything is fine. You've hooked it up right.
Not being able to find AM, is in the new radio.
You need to look to see how to tune to AM.
Maybe the paperwork that came with it!
Jan 13, 2010 | Dewalt DC011 AM/FM Radio
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
Boss marine am fm cd reciever wont get fm radio
it could be either the fm antenna connection or the fm tuner inside the radio.
Mar 29, 2009 | Car Audio & Video
My 2000 Toyota Solara radio has started to lose a strong signal.
Check mounting surfaces at antenna. Corrosion or looseness and the antenna loses its ground to the body.
Oct 27, 2017 | 2000 Toyota Camry Solara
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
My FM radio is not working after install ......
Hi , you may buy a portable fm antena adaptable in car body .
and install connect to antena plug and then good fm signal.
Nov 14, 2007 | Sony CDX-454RF 10-Disc CD Changer
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
