Question about Vacuums
Robot will not automatically start cleaning, also, the light stays blinking, even though vacuum is fully charged, while still attached to charging port. How do I fix this?
SOURCE: help
Same thing happened to me, I called the company, and they told me to remove the battery, press the on button for 5 seconds, which clears the system, replace the battery and do a long charge 12 hours. I'm in the process of doing that now.
Posted on Apr 25, 2008
  • 3 Answers
SOURCE: i robot won't go forward
Posted on Mar 30, 2009
Apache Server at Port 80
Posted on May 29, 2009
  • 61 Answers
SOURCE: The green light is on as though the battery is
Remove the battery, hold down the POWER button for ten seconds, then put the battery back in and charge overnight. If it still tells you it's out of power as soon as you start it, it's time for a new battery.
Posted on Sep 01, 2009
SOURCE: My Electrolux Pronto is not charging. When I put
Call electrolux there was a battery recall
Posted on Apr 17, 2010
How do robotic vacuum cleaners work?
They continually suck air, when they hit a surface change automatically change direction to clean overall all accesible places.
Sep 06, 2016 | Bissell SpotBot Robotic Wet/Dry Vacuum
My robot vaccum stopped moving and the brushes stopped turning
is the battery getting fully charged? check to see that it is and it gets seated in the charging dock station correctly and charging lights come on.
Mar 05, 2016 | Bissell 1200-2 Bagless Robotic Vacuum
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Why does navigator freestyle shark vacuum light blink even after charged?
I have had 2 Shark Cordless Freestyle vacuums. The first one, when it was fully charged, the blue light would glow softly. The newest one has a flashing blue light that you can see from outer space. Light is supposed to keep flashing even when it is fully charged. Very annoyed that they changed this feature.
Jun 09, 2014 | Shark Navigator Freestyle Stick Vacuum -...
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
After I press clean, my irobot works for about 5 minutes than stops and everything goes out, includiing lights on the robot, and i have to manually put it on the charger. Would I be right in thinking that...
possible your battery has a damage allready need for replacement. but try to fully charge your battery then after test it if it a minutes that use the problem happens againyour battery has damage.
Feb 23, 2011 | iRobot 53501 Roomba 500 Series Vacuum...
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
Jul 19, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba 4108 does not charge
Try resetting your Roomba by removing the battery, unplug the charging connector, hold down the Power button for 30 seconds. This will reset the charging system, replace your battery, connect your charger and see what happens. By the way do you also have a homebase ? If so try that too
Dec 12, 2008 | Roomba Robotic Floor Bagless Vacuum
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
