Question about Gaggia Coffee Makers & Espresso Machines
I have a gaggia brera for 6 months now e it initiated liking inside the coffe cake bean, some time the liking is outside of the reservoir below. What can i do to fix?,
  • 1089 Answers
SOURCE: Gaggia Titanium dumps ground coffe inside unit
Hi
You have 2 knobs in the bean hopper. The small one is set to the most positive. Turn it back 1 click from the plus and that should take care of your problem. When you have a clean brew unit it will make the first coffee but a little coffee is left in the brew unit and when it tries to make the second coffee a full charge and the little that was left cause an over charge, and dumps the coffee without making anything.
Posted on Jun 17, 2009
EsWorld
  • 1618 Answers
SOURCE: will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Posted on Feb 05, 2010
EsWorld
  • 1618 Answers
SOURCE: Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Posted on Apr 16, 2010
  • 24 Answers
SOURCE: I use an oily bean with my Gaggia Brera which has
Oily beans means the coffee is old and/or over roasted. I reccomend using fresher beans. i recommend buying less coffee more often. i usually use a paper towel and wipe out the "hopper" where the beans sit.. hope that helps
Posted on Mar 08, 2011
SOURCE: Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
Posted on Apr 11, 2011
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
Gaggia brera descale stays on
try to hold the steam/hotwater button for 5-6 seconds.
Aug 15, 2014 | Gaggia Brera Coffee Maker
Descale alarm wo'nt turn off after a full descale.
You have to reset this manually after descaling. This is done by pressing the bean selector button for 6 seconds.
Nov 10, 2013 | Gaggia Brera Coffee Maker
Gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
May 13, 2012 | Gaggia Brera Coffee Maker
Brera: coffee grounds inside + internal leak
finer grind setting and non oily beans did the trick for me.......
Apr 17, 2012 | Gaggia Brera Coffee Maker
I use an oily bean with my Gaggia Brera which has the integrated grinder on it. I know this may eventually clog up the grinder; and so, is there a way to clean the grinder without taking it apart? Is...
Mar 07, 2011 | Gaggia Expresso Machine
Brand new machine. coffee beans are loaded. when trying to make coffee the machine says the beans are empty. thanks
This machine doesn't like oily beans. Your best bet is to buy freshly roasted beans that are roasted to a FC or FC+. Viena, French and Italian roast beans won't work well. Also any beans that you buy at the grocery store will be quite old (often 3 months past roasting date) and they tend to be very oily on the outside.
If you have a coffee stirring stick or a chopstick, lift the cover of the bean hopper and stir the beans and sort of poke them down in the center - that's where the beans stick and can't drop down into the grinding burrs.
If you use oily beans you will need to stir every time or every other time you make a cup. Fresh roasted beans at a slightly lighter roast will work fine.
Oct 09, 2010 | Gaggia Titanium Espresso Machine
Will grind the coffee beans but no water passing
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Hi
Jun 17, 2009 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
