CANNOT GET INTO WIRELESS THERMOSTAT TO ALTER PROGRAMME
Why did thermostat stop working?
First of all, remove the thermostat from the wall and determine whether batteries should be replaced. If fresh batteries are installed, you should be able to program it while it is detached. If this doesn't work, the thermostat may have failed and will have to be replaced.
Jan 04, 2016 | Honeywell Programmable Thermostat Heater
Is there a way to use a remote thermostat on a REH-20 fb-p rinnai heater?
No you may find yourself in trouble with your insurance co if you alter the manufacturers appliance which has approved by a regulating body
Dec 14, 2014 | Rinnai Heating & Cooling
I have a bush wm1207tve washingmachome. I put it on delay for 6hrs, but forgot to turn it on. Now it won't let me do anything other than that program with 6hr delay!! I took the plug out of socket twice,...
Needs the dealer /agent with their laptop to re-programme the programmer ,better still buy a cheap one with manual knobs and no electronics
Dec 09, 2013 | Cars & Trucks
Sharp ar 5520
Check programme setup. before printing you should have a setup window to alter the shading same place where you enter number of copies required
Oct 31, 2013 | Office Equipment & Supplies
Netgear adaptor won't recognize 2wire 420
If you wish to unlock this Huawei E960 password.... Call +2347035041294... Skype: mickyhandsome2010
Oct 17, 2013 | NetGear WNCE4004 IEEE 802.11n 450 Mbps...
I've got a panasonic sd256 but started the programme on bake instead of bake raisin and now it won't let me alter the setting. How can I stop and start again
Hold the select stop start button until the display goes blank then press the select button.
This works on my SD256
Sep 09, 2013 | Kitchen Appliances - Others
When I print avery label 74520 on my HP Office Jet Pro 8500, it prints too far to the left on the paper label.
You have to setup printer details, not to sure of programme, if word try looking under mailings/envelopes. There you have the choice to alter the details of the item you wish to use as a template. Good luck.
Peter.
Mar 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I can not uninstall the wireless adapter program
The procedure to uninstall a programme or application is to go to the control panel find the programme name click onto it and click uninstall.This should uninstall it.Sometimes windows can't uninstall files because it can't find the file or it been changed or it's somewhere else on the hard disc.
Aug 07, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Incorrect command line parameter?
i had the problem in installation of yahoo messenger it gives the messege that in correct command linepatametrer problem. just go to start control panet addremove programme and uninstall the yahoo with his all features. then go to yahoo and find the 7 or 7.5 version and download and install it. it will work BUT it will gives you the messege that u r using the older version go to this webside and down the latest version of yahoo messenger. go and find the 8.1.0.421 and download it.
alter that when u installing it it will computer will gives you the messege that u allresdy install the latest version if u r installing this one go and unistall the other. go to add remove programme and uninstall that version and reinstall the latest 8.1.0.421. when it done. give it ur id and password and make fun......
Oct 12, 2009 | Yahoo Messenger
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
