I have just changed my old bt tv box for a new one and youview can't find any aerial channels can you help.
  • 1,259 Answers
You need the correct antenna and setup. How to Choose the Best Over the Air Antenna for Free HDTV
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Posted on Dec 04, 2016
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
How do I auto scan my youview box
You must have it connected to an aerial which receives digital signals into the aerial socket at rear.then go into the menu of the youviewbox and auto scan for all the channels it can pick up.i assume your aerial is pointing in the right direction.you can get a rough idea by looking at any aerials on neighbouring houses.once it completes the scan you must save or store those channels before exiting the menu.then the epg ( electronic program guide )will update and you should be able to select any program using the remote.i also assume the box is a working model and not been corrupted by a failed firmware update or damaged in anyway to any rear connectors.these boxes are very simple to set up so if you do get stuck you can try using the free fone number for talktalk.
Apr 24, 2015 | Humax Dtr-T1000 Youview Digital Tv...
My grandad recently got a youview box from BT when the engineer came to install it he somehow deleted all the freeview channels and now he can't retuneit its like the TV is not receiving a signal
Sorry, but I think you have to contact BT close to your granddad and ask them to send a tech to restore the settings.
In the mean time you can check if all cables are still in place, but I can't come over to do that.
Apr 17, 2015 | Televison & Video
Hoe do I connect a sonytv KDL26EX302 to bt tv
In order to connect your TV - any sort - you need:-
1. A BT broadband package.
2. A BT YouView box.
3. A network connection to your HomeHub or other router.
If one of these is missing (or if your broadband connection is too slow) you will not be able to connect to BT TV.
If you have all 3, then on the TV select the signal source to the socket that the YouView box is connected to and it will be installed automatically.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Televison & Video
How do I access bt sport using my remote ?
H
Please bear with me as I do a little explaining since I've just got it sorted myself ! BTSport is available to anyone with BT Broadband, however you cannot get it on a normal TV. I have a YouView box and with BT Infinity I can BTSport1, BTSport2 & ESPN on my YouView box (Channels 507, 608, 509) played through my TV. My TV however will not pick up the channels. Just says they are "scrambled".They also appear to be available on Sky (channels 413, 414, 417) and Virgin (channels 547, 548, 529).
I strongly suspect that the only way to see these channels without a YouView box, Sky, or Virgin is on line through your computer.
Hope this answers your enquiry.
Nov 12, 2014 | Computers & Internet
Why does the youview box fail to find any channels?
No aerial connection. Badly terminated cable/plug ends. Incorrect sockets connected. Box relocated from another site with a different TV transmitter, so it needs a factory reset before it will do a retune from scratch.
Sep 05, 2014 | Televison & Video
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
Noise (sand noise) when connected to BT Youview
Did you connect to the right channel ? Automatic or manual adjusted.
Dec 15, 2017 | Philips Televison & Video
Televison & Video Logo
Top Televison & Video Experts
