Question about Dyson DC58 Bagless Cordless Hand Vac
I have a Dyson handheld and when I press the MAX button the vacuum starts going on the off then on then off. When not in the MAX mode it works fine.
  • 10865 Answers
SOURCE: My Dyson DC07 won't turn on!
you may have a broken belt. Bad news regarding all Dyson's. You can't replace just the belt your self. You have to purchase a new belt assembly which includes the gears. And it wont be cheap. I would call it a design flaw but i am sure that dyson calls it a profit scheme.
Posted on Mar 29, 2009
  • 389 Answers
SOURCE: Removing the battery
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear.
Posted on Apr 18, 2009
  • 389 Answers
SOURCE: Dyson DC16 Handheld Vacuum Cleaner Manual
Yes! Go to Click on "using your dyson", then (next window) on "select your model", then (next window) on "select your model" again, then (next window) on "DC user guide". And there you are, you've got a copy of the user manual.
Please remember to rate this response. Thanks!
Posted on May 17, 2009
  • 357 Answers
SOURCE: Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
Posted on Aug 07, 2009
  • 10 Answers
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Posted on Jul 28, 2010
The V6 seems to be permanently on 'Max'
Hi Sandy, it's Jack at Dyson.
Our V6 cord-free vacuums have two power modes. There's regular high power for day to day vacuuming tasks, and Max mode for tackling really stubborn dirt, clinging pet hair etc.
To change between modes, you need to hold down the red on/off trigger so the vacuum is running. Then at the same time, press and release the illuminated Max button on the rear of the main body. You'll hear a change in the sound the motor makes when you switch between modes:
v6-seems-permanently-max-yb2iqq4t3gdfozzh4fdwdnjv-3-0.jpg I hope this helps. If you'd like any further advice, our experts are standing by. You can reach the Dyson Customer Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Mar 06, 2016 | Dyson V6 Bagless Cordless Stick Vac
I can't the the max mode to turn off. How do I fix this?
Hi Kayla, it's Jack at Dyson.
To switch between Max mode and regular mode, first hold down the red on/off trigger, so the vacuum is running. Then at the same time, press and release the Max button on the rear of the machine. The machine is designed in this way to make Max button can't be activated accidentally. When running in Max mode, the button will light up.
I hope this information helps, If you'd like any additional advice, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 26, 2015 | Dyson V6 Absolute Bagless Cordless Hand...
I have had my dyson dc59 for about 3 months. Wheni try to turn it on by the trigger it won't start. I know it has a full charge so with my messing around with it i pressed the max button and it turned...
Hi Jeff, it's Jack at Dyson.
The issue you're describing with your DC59 sounds very unusual, but I'm sure we can help. Like all Dyson cordless and handheld vacuums, DC59 is backed with our 2-year Dyson parts and labour guarantee.
When you have your machine fully charged and easily to hand, please give us a call so we can talk you through some simple diagnostic checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 23, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How do I change from MAX to normal on my Dyson59 vacuum cleaner.
Hi Betty, it's Jack at Dyson.
To change your DC59's power level from Max to normal, just hold down the on/off trigger so the vacuum is running, then at the same time press and release the Boost button on the rear of the machine. When Max mode is activated, the Boost button will light up - when normal mode is activated, the Button will not light up.
I hope this helps, but if you'd like further information or advice please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 03, 2014 | Vacuums
How do I remove battery from hand held vacuum?
Hi Alan, it's Jack at Dyson.
If you own a Dyson DC16 handheld vacuum, the battery removes at the push of a button. Press the catch and pull the battery away from the machine horizontally. If you're fitting a replacement battery, this will attach to the machine in the same way.
If you own a different model of Dyson handheld vacuum, please reply to confirm which model you have so we can provide further advice.
Alternatively, if you'd prefer you're welcome to call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 25, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Max is on
Hi there, it's Jack at Dyson.
From what you've described, it sounds as if the battery may not be charged. If your machine has been allowed to recharge for over 5.5 hours but still has no power, there may be an issue with the battery or the charger. However in order to confirm this, and to help resolve the issue, we'd need to take you through some further diagnostic checks over the phone when you have the machine to hand.
When you have a moment, please give the Dyson Customer Helpline a call - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 03, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
Why is my Dyson DC59 is empty but the max light is on and it won't work
it would mean that your air flow is gone or you have a plug in it some where about 90 % of all bag full or max light work on air flow
Jul 26, 2014 | Dyson DC44 Animal Cordless Vacuum Handheld...
Dyson dc35 max button gets stuck
I found my MAX button had a crack in it, which was causing it to grab on the sides of the button hole, I tried various methods to free the button, but in the end I resorted to ripping the button cap off. Below the button cap is the max/normal switch itself. It now functions as it should, but is missing the MAX button cap, not really an issue for me, though if I could find a new MAX button somewhere I'd put it on, it looks like it should push straight on.
Jan 29, 2013 | Dyson DC35 Handheld Vacuum
My dyson dc35 hand vacuum cuts out constantly while in use despite a full charge and clean filter
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson is acting that way. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for readers, use code: FIXYA10
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Jul 08, 2012 | Dyson DC35 Handheld Vacuum
Dyson dc35 button won't stay on
Where can I order the switch from?
May 19, 2012 | Dyson DC35 Handheld Vacuum
Dyson DC58 Bagless Cordless Hand Vac Logo
43 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
