Question about Bell Lands Phones
My Bell phones simply keep flashing BASE 1 Please recommend ALL the possible solutions to connect. George
SOURCE: BT Synergy 2150 Cordless Phone
As far as I can understand your problem, there is nothing wrong, just view the new calls ( options/caller id/options/view/ up and down arrows to scroll through caller id's). New calls message will then disappear, although it doesn't really matter if you don't do any of this.
Posted on May 15, 2007
  • 518 Answers
SOURCE: Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Posted on Jan 23, 2008
Petryxa
  • 40 Answers
SOURCE: I have a 3 phone
May be your base just doesn't support 3 phones at the same time. Try to turn off one of the working phones, reboot your base and reregister the one that you have problems with. If it works then turn on the turnedoff phone and try to register it, if the same problem appears with this one, then your base just doesn't support 3 phones at the same time.
Posted on Jul 24, 2008
  • 1894 Answers
SOURCE: uniden powermax 5.8 GHz not working
have you tried a hard reset. please leave the phone plugged off from wall power for one night and then try starting.
this may start the phone normally and problem will get solved many times.
thank you
Posted on Aug 12, 2008
  • 1214 Answers
SOURCE: FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Posted on Jan 26, 2009
Hi there I have a bell cordless phone model: edge 2000 / 2005T. On the display screen it keeps on flashing BASE 1. I don't get any calls or make any calls. Please can some-one tell me how i can fix...
Hello there and welcome to Fixya!
I think your handset needs to be reset .First of all open the base of your cordless phone ,it will have a recharging battery packed inside. remove the plugs so it can be free for 10 seconds. and then attach again , and see if it resets and your problems get solved
Do comment if it helps you in any manner
Apr 17, 2011 | Cell Phones
Uniden powermax 5.8 GHz not working
thank you
Aug 12, 2008 | Uniden Cordless phone EXS9950
Hi - my 2yrold was fiddling with the handset, and now we have a flashing 'base 1' display. Each time we dial, it reverts back to the flashing message. I've tried unplugging the unit and leaving it...
You 2 year old disconnected the handset from the base. The handset is asking to be connected to the base. If you have the owners manual it will tell you the sequence you need to do to reconnect the handset to the base. If not, google the make and model and get the manual on line. sometime sitting the handset on the base several times in sequence will re sink it to the base.
Dec 12, 2017 | Northwestern Bell BELL 36240 Cordless...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Mar 04, 2009 | Uniden Lands Phones
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
REGISTRATION
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
I have a 3 phone 1 base cordless set. Well I have one phone that keeps saying searching and then it says out of range. well the other phones work. I tried to re register it and it still won't work. Ti a...
Jul 24, 2008 | Lands Phones
BT Studio 3100 handset 1. Display flashing base 1, cannot go to setup menu, not changed pin code, turned off and on, removed batteries, turned off base unit, waited 20-30secs for all of above and still...
Help
My Bt Studio 3100 cordless telephone ( 2 Pack ). I have carried out the setting up procedures as per instructions.
Handset batteries are fully charged, but I am not getting the dialling tone.
Jul 11, 2008 | Lands Phones
Try this:
Geno
Jan 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Faulty phone
Sure sure i will help you out but please specify the model of your phone..If its GE then you will need to keep it connected to the power supply...If the power supply is cut it will br un-registered automatically..
Oct 30, 2007 | Lands Phones
Lands Phones Logo
32 people viewed this question
Top Bell Lands Phones Experts
RobertFonner
RobertFonner
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Bell Lands Phone Expert? Answer questions, earn points and help others
