Question about Coffee Makers & Espresso Machines
After using the steam to froth milk how do I get it back to make more coffee? I push the middle button again, but it takes so long to switch back.
SOURCE: saeco milk island - no froth
Molly -- re: position of grey plug. I don't think this makes any difference at all. The key issue is to make sure those two slots are clear of debris or moisture. One month on and I have continued to achieve thick frothy milk purely from rinsing the milk island parts under a running tap, leaving them to dry, and then giving a short sharp blow to the two slots in the valve before reassembling.
Good luck
Guest with Solution 2
Posted on Apr 20, 2008
mirran
  • 515 Answers
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: the steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Posted on Feb 14, 2010
Testimonial: "Thank you very much for the advice. I adjusted the black tube and the frothing is back!"
How do i use the steam wand to froth milk
The steam wand to froth milk, you need a certain amount of milk in the cup first, then if you tilt the cup a little towards you, push the steam button and "it should froth your milk right up", but if that doesn't work then I don't know.
Mar 24, 2014 | Bella Espresso Maker - Black
Miele built in. Steam but no froth
Sounds like the venturi tube could be blocked. My model is a CVA 4085 and I can take the assembly out that sucks in the milk, mixes the air and stem and spits out frothed milk. If yours is similar, see if you can can reach the top of the milk outlet tube and rotate the ring around it anti-clockwise (if you were looking up from the bottom) and take the whole assembly out. If you have never taken this out, disassembled it and rinsed everything out thoroughly under a running tap now is a good time to do it. Then check the venturi tube: the clear (ish) bendy plastic tube that that points up and has a cone with a hole in the top. If that hole is blocked you won't get very good froth. If you can't clear it with warm running water then VERY CAREFULLY use a small needle to push through the hole at the top, then put everything back together.
Good luck.
Jan 14, 2013 | Miele Coffee System
Coffee maker not frothing milk
The tube on the "ball assembly" which connects to the "milk" tank may be missing an O-ring. If this O-ring is missing, the steam will only siphon a little bit of milk because there is no seal. If it is working properly, the siphon can fill be expected to fill a cup in about 30 -60 seconds.
May 19, 2012 | DeLonghi EC Coffee Makers & Espresso...
After frothing the milk it can take ages to reset back to prepare black coffee again. Both lights flash green for up to 15minutes before being ready to make another cup. Does anyone know why?
Hi Jan, This happens because the machine is too hot, due to higher heat being required for the frothing. After frothing, press the button as if you would want to brew a cup,I should blink. At that very same time, turn the steam knob fully open to let some steam out, ,which will lower the inside temperature. This should solve your issue.. Good luck, Claudio
Dec 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
We've had the Rancilio Audrey now for a year and still not have had a perfect cappucino. 1. Milk. We use 3.5 dairy milk, cold before going under spout. 2. What is the middle (steam) button used for? ...
  1. That is the right milk. Use a thermometer with the milk.
  2. The middle button is used for steam. It engages the high themostat for steam.
    1. Slightly open the steam valve
    2. Turn on the middle button
    3. Keep the end of the steam wand slightly above the milk surface (0.5 mm) so the steam incorporates air into the milk. (Takes practice)
    4. Open the steam valve as the boiler heats up. (Takes practice)
    5. When the milk get to 74 C (165 F) immerse the steam wand into the milk and heat to 82 C (185 F)
    6. Turn off the middle button and shut the valve.
  3. For 90 ml of coffee, use 14 gram of ground coffee. The coffee scoop that came with the machine holds 7 grams of ground coffee as it comes out of a grinder (not packed). Tamp the coffee after it is in the sieve.
Jan 01, 2011 | Rancilio Audrey
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Water does not flow through the coffee group but only exits viasteam pipe. Decalcifying and cleaning or resetting factory settings do not solve the problem. what to do?. The problem occurs after I have...
Hi
When you are finished with steaming, try pushing the steam button again and then opening the steam valve to purge the steam. Do this until the water flows freely. You should hear the pump change tone. If you have a pre grind button, try that without putting any coffee in the pre ground chute, then push a medium coffee. Water should flow through the brew unit freely. If not, you are getting a blockage in the brew unit. If it does, your grind on the machine might be too fine. Change to a coarser grind and try again. It usually takes 3 cycles before the grind is in effect.
Aug 22, 2009 | Gaggia Titanium Espresso Machine
Jul 11, 2008 | Saeco Incanto Classic Espresso Machine
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
