Question about Car Audio & Video
Installing a pioneer avh p4000dvd to a 2002 Ford focus
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
I need a avh-p4000dvd wiring diagram
i have the manual for it .. i hope this helps -- ther are phone numbers to call Pioneer to get further information
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-P4000DVD_OperationManual0123.pdf
Oct 30, 2010 | Pioneer AVH-P4000DVD Monitor
How do i play video from usb on a Pioneer AVH-P4000DVD?
You can NOT view video using USB on this unit. Video has to come from the AV inputs (RCA connections) or from an IPOD connection. Sorry.
Jun 30, 2009 | Pioneer AVH-P4000DVD Monitor
How to unlock the eject button on a pioneer avh-p4000dvd
remove ur eject option from menu bar and for tchnician help contact http://tinyurl.com/mtgjzz
Jun 22, 2009 | Pioneer AVH-P4000DVD Monitor
What's the recommended camera for avh-p4000dvd pioneer unit
Pioneer recommends Pioneer ND-BC2, but you should be able to use any with a descent viewing angle and RCA connections.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Watch a dvd while driving pioneer AVH-P4000 DVD
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Mar 03, 2009 | Pioneer AVH-P4000DVD Monitor
CHANGE REGION 1 TO 2 FOR AVH-P4000DVD
Kali Mera, Ti Kanis?
I have been looking in to this, but there does not seem to be a hack available.
http://www.videohelp.com/dvdhacks?dvdplayer=AVH-P4000DVD&hits=50
Signomi
Oct 24, 2008 | Pioneer AVH-P4000DVD Monitor
Car Audio & Video Logo
64 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
