Question about Kitchen Ranges
How to replace the EOC on my FGFL67DCK stove
I woke up to beeping and the stove flashing F11. After leaving the door open for a bit, it finally shut off. So I was able to reset the clock, but now the clock display won't stay lit up. Do I need to replace the EOC? And if so do you have a video on how to do that?
SOURCE: oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Posted on Dec 06, 2007
aborcass
  • 2651 Answers
SOURCE: clock doesn't stay lit up
To turn the time of day display OFF or ON in the display press and hold for 15 seconds (the control will beep
once) and then release. This feature does not remove the set time of day from the memory of the control. When the display
is turned OFF the time of day will re-appear for a few seconds any time the pad is touched
Posted on Mar 04, 2008
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
SOURCE: Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Posted on Apr 22, 2009
SOURCE: 94 Jeep Grand Cherokee diagram panel flashes on
there are two buttons on the diagram panel screen, push and hold top button and a one of the entries will start to blink, then you use the bottom button to change the entry, when you are ready to move to the next entry push the top button again.
Posted on Aug 07, 2009
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
What is the EOC and how much does it cost to replace? Can I replace it myself or do I need a professional to replace it?
kenmore stove model #c970635326 serial #nf70205945 is showing f11 on the clock and a constant beeping noise.
when you unplug and plug it back on the clock show 12:00 for a few seconds then the f11 shows again and the continuing beeping noise
how much is an eoc to replace....can i do it myself....
Jan 09, 2011 | Kenmore Ovens
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stove flashed F11 and then locked the oven door
HI, this is control failure. the logic chip set is damaged. this is causing these erratic commands and the unauthorized locking of the oven door. you will need ot replace the control in this case.(EOC/clock)
May 29, 2009 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire, Gas Oven Door
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Oct 10, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Beeping F11 error on Frigidaire stove. We have to stut off from the breaker to stove beeping
Jul 26, 2008 | Kitchen Ranges
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
My frigdaire stove door finally opened manually from behind but
F9 code: An F9 code indicates the EOC has detected a problem with the motor door latch assembly. Check the contacts of the lock switch, wiring to the lock motor assembly, and the lock motor.
Dec 16, 2007 | Frigidaire FEF455BB Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
