Question about Sewing Machines
Im having trouble with the needlr threaf locking to the bobbin thread. just have 2 long threads after srwing. im sewing upholstrry lrather up to 4mm thick
  • Sewing Machines Master
  • 8,899 Answers
Check whether it occurs only when sewing thick upholstery fabric or on any fabric. If it is only on the upholstery, then the fabric is most likely causing the needle to deflect so it is not intercepting the bobbin thread. Make sure to use a brand new sharp needle and one that is heavy enough to penetrate the fabric without bending. If it occurs on any fabric, then the machine is most likely out of time. Search for sewing machine timing or take it for service.
Posted on Dec 04, 2016
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
Good day!
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I'm in trouble deep-I was trying to fix an old
Good day!
Good day!
Jun 06, 2011 | Toyota SE-06 Mechanical Sewing Machine
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
My machine wont pick up the bobbin thread, and when it does, and I start sewing, it keeps jamming, and the thread locks around the bobbin spindle. It keeps sewing in one spot, which I have to cut the...
check that the bobbin thread is pulled thru 'the tongue' of the bobbin case: that is what controls general tension of the lower thread. also make sure the upper thread is threaded thru the tension disk and the disk is 'grabbing it'.
Feb 02, 2010 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
