Question about Vehicle Parts & Accessories
Vectra non starter. fault code on diagnostics reads ''immobiliser wrong signal and MIL lamp high voltage?? happened all of a sudden!! leads are new, coil pack new and camshaft sensor new!! HELP!!
I have a vectra 1.9 cdti diesal the engine manigment light come on all the time turbo cuts out help me fault codes p0234
Posted on Sep 05, 2009
1999. What are the probable causes of DTC P1624?
Definition of Diagnostic Trouble Code P1623 Audi: Data Bus Powertrain No Communication BMW: Pedal Position Sensor Potentiometer Supply Buick: Transmission Temp Pull-Up Resistor Cadillac: Transmission Temp Pull-Up Resistor Chevrolet: Transmission Temp Pull-Up Resistor Chrysler: ASD Relay/Control De-Energize Too Soon Dodge: ASD Relay/Control De-Energize Too Soon Ford: Code word/id number-write/read error GMC: Transmission Temp Pull-Up Resistor Hyundai: Diagnostic Lamp Powerstage Malfunction Jeep: ASD Relay/Control De-Energize Too Soon Land Rover: Immobilisation ECU code storage fault.Last occurrence - signal fault Lincoln: Code word/id number-write/read error Mazda: Immobilizer Code Word/ID Number Write Failure Mercury: Code word/id number-write/read error Oldsmobile: Transmission Temp Pull-Up Resistor Pontiac: Transmission Temp Pull-Up Resistor Saturn: Transmission Temp Pull-Up Resistor Volkswagen: Data Bus Powertrain No Communication Volvo: ETS .amp / MIL on
Jun 27, 2015 | Hyundai Elantra Cars & Trucks
My 2001 Chrysler Concorde will not start. I had the starter replaced when I got the codes p1684p1685. Now after the new starter was put in it still doesn't start I got the code p1684 I tried to have it...
Have
the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units. If the starter is cranking the engine but it will not start also check the key battery as the immobiliser may not be activating.
Jun 10, 2013 | Cars & Trucks
Fault code 151
We guess DTC P0151... essentially the same as P0136 and P0137 and P0131, a P0151 code refers to the first oxygen sensor on Bank 2 . P0151 means the O2 oxygen sensor's voltage remained low for longer than 2 minutes. This, is interpreted by the ECM as a low voltage condition and sets the MIL. Bank 2 Sensor 1 is located in front of the catalytic converter.
There may be no visible symptoms to the driver, other than the MIL (Check Engine / Service Engine Soon) illumination.
A code P0151 may mean that one or more of the following has happened:
Faulty o2 oxygen sensor
Short to voltage on O2 signal circuit
High resistance or open on O2 signal circuit
Possible Solutions:
Replace faulty sensor
Repair short, open, or high resistance on o2 signal circuit
Sep 07, 2011 | BMW X5 Series Cars & Trucks
I have a 1997 Camaro that the check engine light will not come on . It should come on when the ignition is turned on before the motor is started , but it never comes on. I took the instrument panel out an...
Factory service information has a diagnostic procedure for thing's to check . Hooking up a factory scan tool (tech2) would be the first step ,Checking for DTC'S - diagnostic trouble code's
DTC P1661 Malfunction Indicator Lamp (MIL) Control Circuit
A voltage is supplied directly to the malfunction indicator lamp (MIL). The powertrain control module (PCM) controls the lamp by grounding the control circuit via an internal switch called a driver. The primary function of the driver is to supply the ground for the component being controlled. Each driver has a fault line which is monitored by the PCM. When the PCM is commanding a component ON, the voltage of the control circuit should be near 0 volts. When the PCM is commanding the control circuit to a component OFF, the voltage potential of the circuit should be near battery voltage. If the fault detection circuit senses a voltage other than what is expected, the fault line status will change causing the DTC to set.
Perform the Powertrain On-Board Diagnostic System Check first, when the following conditions are present:
• When the MIL does not turn ON when the the ignition switch is turned to the RUN position
Malfunction Indicator Lamp (MIL) Inoperative
Circuit Description
There should be a steady MIL with the ignition ON and the engine not running. Ignition feed voltage is supplied directly to the MIL bulb. The Powertrain Control Module (PCM) turns the MIL ON by grounding the MIL control circuit. No MIL with the key ON, engine not running and DTC P1641 set suggests an open in the MIL control circuit.
The diagnostic procedure for this is 17 step's . , the basic thing's checking B+ voltage at the connector for the IPC , checking the control circuit at the PCM connector , using the scan tool to check for bidirectional control of the MIL lamp . Checking wiring circuit for the control circuit . Disconnect the PCM connector that has control side wire for the MIL an ground it an see if the light lights . If it does ,replace the PCM . Check for open wire . ETC........
Check the MIL control circuit for an open.
If the MIL control circuit is open, repair as necessary. Refer to Wiring Repairs .
Finding wire diagrams would be a big help to you .
Nov 10, 2017 | 1997 Chevrolet Camaro
CODE PO372
The distributor ignition system supplies two timing inputs to the PCM, a high resolution signal (180 pulses per one crankshaft revolution) and a low resolution signal (4 pulses per one crankshaft revolution). The high resolution and low resolution circuits toggle between 0 and 5 volts as the camshaft turns. The PCM can determine if one of the timing inputs is not being received by comparing the two inputs.
The following malfunctions to the high resolution circuit will cause a DTC P0372 to set:
• An open. • A short to voltage. • A short to ground. • A defective ignition module within the distributor. Conditions for Setting the DTC • The PCM detects low resolution pulses but no high resolution pulses. Action Taken When the DTC Sets • The PCM will illuminate the Malfunction Indicator Lamp (MIL) when the diagnostic runs and fails. • The PCM will record operating conditions at the time the diagnostic fails. This information will be stored in the Freeze Frame and/or Failure Records. • The injector will be disabled for the entire ignition cycle. Conditions for Clearing the MIL/DTC • The PCM will turn the MIL OFF after three consecutive drive trips that the diagnostic runs and does not fail. • A last test failed (Current DTC) will clear when the diagnostic runs and does not fail. • A History DTC will clear after forty consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic. • PCM battery voltage is interrupted. • Using a Scan tool. Diagnostic Aids • If DTC P1351 and/or DTC P1361 is also set with a DTC P0372, and no external fault can be found, replace the PCM. If only DTC P0372 is set and the distributor connections are OK, replace the distributor. • If distributor components must be replaced, check distributor vent system operation.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 30, 2011 | 1996 Chevrolet Impala SS
Flashing airbag light 4 blinks 6 blinks
This is a code 46 LH Crash Sensor - Not Mounted to Vehicle Properly. Often there is a poor contact on one of the wiring connectors. Some of the problems can happen from a poor connection where everything connects under the drivers side seat.
Here is a list of codes for the airbag light issues.
Air Bag Fault Code Table
AIR BAG DIAGNOSTIC MONITOR FAULT CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest -- No Air Bag Lamp - Inoperative Lamp Circuit or No Ignition Voltage to Diagnostic Monitor
' -- Continuous Air Bag Lamp - Diagnostic Monitor Disconnected or Inoperative
' 12 Low Battery Voltage
' 13 Air Bag Circuit or Crash Sensor Circuit - Shorted to Ground
' 21 Safing Sensor - Not Mounted on Vehicle Properly
' 22 Safing Sensor Output Circuit - Shorted to Battery Voltage
' 23 Safing Sensor Input Feed/Return Circuit Open
' 24 Open in Circuit 944B or Low Resistance in Crash Sensor(s)
' 32 Driver Side Air Bag/Safing Sensor Circuit - High Resistance or Open
' 33 Pin 7 Not Grounded at Diagnostic Monitor
' 34 Driver Side Air Bag/Safing Sensor Circuit - Low Resistance or Shorted
' 35 Low Resistance Across Pins 8 and 9 at Diagnostic Monitor
' 41 Crash Sensor Circuit - High Resistance or Open
' 44 RH Crash Sensor - Not Mounted to Vehicle Properly
' 45 Center Radiator Crash Sensor - Not Mounted to Vehicle Properly
' 46 LH Crash Sensor - Not Mounted to Vehicle Properly
' 51 Diagnostic Monitor Internal Thermal Fuse - Blown and Short to Ground No Longer Exists
' 52 Backup Power Supply - Voltage Boost Fault
' 53 Internal Diagnostic Monitor Fault
Lowest -- Rapid Continuous Flashing of Air Bag Lamp - All Crash Sensors Disconnected
Hope this helps...
May 05, 2011 | 2003 Ford Escape
Code po650, po332,p1875 comes on what do they mean exactly,whats wrong
CODE PO650 MALFUNCTION INDICATOR LAMP CIRCUIT MALFUNCTION CONDITIONS. POSSIBLE CAUSES MIL CONTROL CIRCUIT IS OPEN , SHORTED TO GROUND TO SYSTEM POWER,MIL CONTROL POWER CIRCUIT OPEN IN THE INSTRUMENT CLUSTER, MIL THE LAMP IS DAMAGED OR HAS FAILED,INSTRUMENT CLUSTER OR THE PCM HAS FAILED. CODE PO332 KNOCK SENSOR CIRCUIT LOW INPUT BANK 2 CONDITIONS, POSSIBLE CAUSE KNOCK SENSOR FAILED, CODE P1875 4WD LOW SWITCH CIRCUIT MALFUNCTION CONDITIONS FOR TRANSMISSIONS 4L60E 4L80E, POSSIBLE CAUSES 4WD SWITCH LOW SIGNAL CIRCUIT IS OPEN OR SHORTED TO GROUND, 4WD LOW SWITCH IS DAMAGED OR IT HAS FAILED,PCM HAS FAILED.
Mar 14, 2011 | 2003 Chevrolet Avalanche
Code p1295
iam posting the hyundai code list i have that the vehicle manufacturer lists
P1100 Manifold Absolute Pressure Sensor Range/Performance
P1102 Manifold Absolute Pressure Sensor Circuit Low Input
P1103 Manifold Absolute Pressure Sensor Circuit High Input
P1123 Lang Term Fuel Trim Adaptive Too Lean
P1124 Long Term Fuel Trim Adaptive Too Rich
P1127 Long Term Fuel Trim Multiplier Too Rich
P1128 Long Term Fuel Trim Multiplier Too Lean
P1134 HO2S Bank 1 Sensor 1 Transition Time Switch (Bank 1 Sensor I)
P1154 HO2S Bank 2 Sensor 1 Transition Time Switch (Bank 2 Sensor 1)
P1166 HO2S Bank 1 Sensor 1 Controller Adaptive Diagnosis Fault (Bank 1)
P1167 HO2S Bank 1 Sensor 1 Controller Adaptive Diagnosis Fault (Bank 2)
P1168 HO2S Bank 1 Sensor 1 Heater Power Incorrect (Bank 1 Sensor 2)
P1169 HO2S Bank 1 Sensor 1 Heater Power incorrect (Bank 2 Sensor 2)
P1372 Segment Time Incorrect
P1400 Manifold Differential Pressure Sensor Circuit
P1440 EVAP System Vent Solenoid Circuit
P1443 EVAP System Fault (Fuel Tank Cap Missing)
P1510 Idle Control Valve Opening Circuit Shorted (Coil 1)
P1511 Idle Control Valve Command Signal Shorted (Coil 2)
P1513 Idle Air Control Valve Opening Coil Circuit Open (Coil 1)
P1521 Power Steering Switch Input Circuit
P1529 Customer Snapshot Request VIA CAN
P1552 Idle Air Control Valve Closing Coil Circuit Shorted
P1553 Idle Air Control Valve Closing Coil Circuit Open
P1586 Encoding Signal Circuit Not Rationale
P1602 Serial Communication Fault with Transmission Control Unit
P1605 Rough Road Sensor Circuit
P1606 Rough Road Sensor Circuit Not Valid
P1611 MIL Request Signal Circuit Low Input
P1613 ECU Self-Test Failed
P1614 MIL Request Signal Circuit High Input
P1616 Main Relay Fault
P1623 Diagnostic Lamp Power Stage Fault
P1624 MIL On Request Signal//Cooling Fan Relay Low Circuit
P1625 Cooling Fan Relay High Circuit
P1665 Power Stage Group 'A' Fault
P1670 Power Stage Group 'B' Fault
Feb 10, 2011 | 2008 Hyundai Sonata
I have a check engine alarm on my '96 honda civic ex and diagnostics result in code p0138. What does this mean?
The Heated Oxygen Sensor (2) located rear of catalytic converter produces an output signal relative to oxygen storage capacity of catalytic converter. Ho2S 2 signal is less active than signal produced by front oxygen sensor. This code sets when HO2 Sensor voltage is greater than 999 mV for more than 2 minutes (time depends on model. Could be as high as 4 minutes)
There may be no noticeable symptoms except for MIL illumination. Possible high fuel pressure can over rich the system.
A code P0138 may mean that one or more of the following has happened:
  • Faulty O2 sensor
  • Short to battery voltage in O2 sensor signal circuit
  • High fuel pressure (not as likely)
Here are some potential solutions:
  • Replace O2 sensor
  • Repair short to battery voltage in o2 sensor signal circuit
Feb 10, 2011 | 1996 Honda Civic
Hyundai santa fe 2001
Car error codes::
Diagnostic Trouble Code Storage Condition Remedy
P0100 Mass Air Flow Sensor Voltage High C-8
P0100 Mass Air Flow Sensor Voltage Low C-8
P0110 Intake Air Temperature Voltage High C-10
P0110 Intake Air Temperature Voltage Low C-10
P0115 Coolant Temperature Voltage High C-9
P0115 Coolant Temperature Voltage Low C-9
P0120 Throttle Position Sensor (TPS) Voltage High C-7
P0120 Throttle Position Sensor (TPS) Voltage Low C-7
P0130 O2 Sensor 1 Circuit Voltage High C-30
P0130 O2 Sensor 1 Circuit Voltage Low C-30
P0130 O2 Sensor 1 Open Circuit C-30
P0150 O2 Sensor 2 Circuit Voltage High C-31
P0150 O2 Sensor 2 Circuit Voltage Low C-31
P0150 O2 Sensor 2 Open Circuit C-31
P0201 Injector Valve 1 Voltage High C-20
P0201 Injector Valve 1 Voltage Low C-20
P0201 Injector Valve 1 Open Circuit C-20
P0202 Injector Valve 2 Voltage High C-21
P0202 Injector Valve 2 Voltage Low C-21
P0202 Injector Valve 2 Open Circuit C-21
P0203 Injector Valve 3 Voltage High C-22
P0203 Injector Valve 3 Voltage Low C-22
P0203 Injector Valve 3 Open Circuit C-22
P0204 Injector Valve 4 Voltage High C-23
P0204 Injector Valve 4 Voltage Low C-23
P0204 Injector Valve 4 Open Circuit C-23
P0205 Injector Valve 5 Voltage High C-24
P0205 Injector Valve 5 Voltage Low C-24
P0205 Injector Valve 5 Open Circuit C-24
P0206 Injector Valve 6 Voltage High C-25
P0206 Injector Valve 6 Voltage Low C-25
P0206 Injector Valve 6 Open Circuit C-25
P0230 Fuel Pump Relay Voltage High C-6
P0230 Fuel Pump Relay Voltage Low C-6
P0230 Fuel Pump Relay Open Circuit C-6
P0325 Knock Signal Circuit 1 C-26
P0330 Knock Signal Circuit 2 C-26
P0335 No Engine RPM Signal C-32
P0335 Incorrect RPM Signal C-32
P0340 Hall Sensor Voltage High C-15
P0340 Hall Sensor Voltage Low C-15
P0403 EGR Valve Voltage High C-28
P0403 EGR Valve Voltage Low C-28
P0403 EGR Valve Open Circuit C-28
P0410 Secondary Air Pump Voltage High C-27
P0410 Secondary Air Pump Voltage Low C-27
P0443 Fuel Tank Ventilation Valve Voltage High C-29
P0443 Fuel Tank Ventilation Valve Voltage Low C-29
P0443 Fuel Tank Ventilation Open Circuit C-29
P0500 Vehicle Speed Signal C-42
P0505 Idle Air Control Voltage High C-33
P0505 Idle Air Control Voltage Low C-33
P0550 Power Steering Voltage High C-14
P0550 Power Steering Voltage Low C-14
P0560 Battery Voltage High C-4
P0560 Battery Voltage Low C-4
P0602 Control Module Programming Error C-2
P1110 Intake Manifold Valve 1 Voltage High C-34
P1110 Intake Manifold Valve 1 Voltage Low C-34
P1111 Intake Manifold Valve 2 Voltage High C-35
P1111 Intake Manifold Valve 2 Voltage Low C-35
P1230 Power Supply Relay Secondary Circuit C-3
P1405 EGR Valve Feedb. Voltage High C-28
P1405 EGR Valve Feedb. Voltage Low C-28
P1405 EGR Valve Feedb. Incorrect Signal C-28
P1501 Immobiliser No or Wrong Coding C-5
P1502 Immobiliser No Signal C-5
P1503 Immobiliser Wrong Signal C-5
P1530 A/C Relay Voltage High C-41
P1530 A/C Relay Voltage Low C-41
P1600 Reprogram or Replace Electronic Control Unit (ECU) C-2
P1602 Knock Control Module; Replace ECU C-2
P1690 Check Light Voltage High C-43
P1690 Check Light Voltage Low C-43
P1690 Check Light Open Circuit C-43
P1740 Torque Control Voltage Low C-40
P1740 Continuous Torque Control C-40
These are the error codes:
Jul 08, 2008 | 2001 Hyundai Santa Fe
Vehicle Parts & Accessories Logo
343 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
