Question about DeLonghi Coffee Makers & Espresso Machines
Light wont work on my bco320t delonghi was working just fine till one morning the espresso side won't work . The light won't turn on I can't make any espresso . Only the coffe side works fine .
  • Anonymous Dec 04, 2016
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
  • 4 Answers
SOURCE: DeLonghi EC701 Pump out
I had the same issue. Scale build up in the port that routes water to the boiler outlet for the coffee filter basket. Frother tube was fine.
I used CLR to open it back up. Used 1 part to 4 of water and ran a whole reserviour through the unit. At first, it only dripped and then finally it blew open when the CLR dissolved the scale.
Make sure to run lots of clean water through the unit after so that you don't end up drinking acid with your next cup. I ran about a gallon through to rinse it out.
Posted on Mar 26, 2008
  • 123 Answers
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
Your manual is listed on this page and you will be able to download it.
Good Luck.
Posted on Apr 10, 2008
  • 39 Answers
SOURCE: When making espresso half way through the pump
Most likely you will see the problem when doing a single or double espressos and when just producing hot water. All these three functions work based on specific amounts of water. Most likely your flow meter is not working properly. I replaced my flow meter (< $20) and the unit now works fine.
Posted on Dec 29, 2009
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
The milk is not heating up in my Nespresso Delonghi, can you please help Sharon
Good morning Sharon,by now your problem may have been solved., hope so. Take look at this
http://www.manualsonline/ and see if it helps.
enjoy your coffee,
Jan 06, 2015 | DeLonghi EN670 Fully Automatic Nespresso...
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My delonghi caffee nero machine-the coffee maker wont work,the hot plate doesnt warm either(although the lights come on. the espresso maker part works fine. Someone mentioned there is a fuse which blows...
If expresso maker part works, the fuse is ok. I think that the resistence of the hot plate is interrupted. You must use the guarantee's facilities. I think it is two years available.
Mar 07, 2011 | DeLonghi Caffe Nero BCO264 Espresso &...
Hi, I have a delonghi 3400 espresso machine. When I turn it on, it says "turn the steam knob". I turned the steam knob to "on" and nothing happens. I pushed all the buttons and...
you must purge the machine first, by waiting till the light turns on then slowly turn steam knob until a steady stream of water appears.Make sure unit is full of water.
Feb 17, 2011 | DeLonghi EAM3400 Espresso Machine
Blinking on/off light won't turn off
It means it's time to "decalcify" your machine. Not sure how to do that, I assume run vinegar or something like that through it. You can turn the blinking light off by holding down the "set clock" and the "set timer" buttons at the same time.
Oct 23, 2009 | DeLonghi DC312T 14-Cup Coffee Maker
Cafe Nero turns on, but will not make coffee
I understand this unit has a fuse inside that blows out. I cannot confirm this as I need to find a special screwdriver to open it. I'll post back my results if possible.
Jul 05, 2007 | DeLonghi Caffe Nero BCO264 Espresso &...
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
