Question about PRINTER Office Equipment & Supplies
TVs HD 945 printer printing excel sheet in 1st page only it's printing 2nd page so on.....
  • 2022 Answers
SOURCE: Printer won't print excel sheets
checka all the lettres are in excel are in black colour only or check the printing mode. bye
Posted on Sep 24, 2007
SOURCE: Problem HP 1320 not responding
Try changing to a new USB cable
Posted on Jun 20, 2008
  • 76 Answers
SOURCE: Printer prints all pages on one sheet of paper
what application are you printing from? also, can you do a print preview to see if there are more than one page? if that works, then your printer mechanism is not following the driver information from the print queue manager.
Posted on Nov 21, 2008
  • 56 Answers
SOURCE: ghost printing
This machine needs a new fuser. That is a common issue.
Posted on Jan 15, 2009
  • 34 Answers
SOURCE: My printer HP Photosmart C7200
Here's a solution. Easy fix. Hope it helps!
Posted on Apr 02, 2009
I cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
Dec 31, 2009 | HP DeskJet 1280 InkJet Printer
Unable to stop printing
did u check the box containing print CURRENT PAGE?????i guess u must not have done this
Oct 22, 2009 | Office Equipment & Supplies
Can't print line
Depending on what version of Excel you are using try the following:
The lines are called gridlines
  1. Click the worksheet.
  2. On the File menu, click Page Setup, and then click the Sheet tab.
  3. Select the Gridlines check box.
Note Large worksheets print faster if you do not select the Gridlines check box.
Please rate this solution...Thanks
Mar 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Samsung ML2010 paper feed
clean the rubber pickup with water or alcohol by cotton cloth and try again
Feb 26, 2009 | Samsung ML 2010 Laser Printer
Black smudges on back of sheet
I don't have this but I try to solve your problem :
In the printer and fax, right click on your device name, choose maintenance and run Cleaning, Deep Cleaning, Roller Cleaning and Bottom Plate Cleaning.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Print quality on oficejet all-in-one hp d135: Re: How do I "clean" / prevent background printing from a prior print request? Problem: 1st print OK; 2nd printed 2nd page with printing from some other source...
Go to the printer's Properties and cancel all printing jobs that are in queue. Switch of the Printer. Restart it.
Take print of any document and see if problem is solved.
Dec 02, 2008 | HP OfficeJet D135 All-In-One InkJet...
Excel formulas
type in "=" and then go to the cell in the 2nd sheet and click on the cell that contains the value you want carried to sheet 1. Then drag copy the forumula in sheet 1 to all the cells you want it to relate to. Now, if you place a value in e.g. A1 of sheet 2, then that same value will appear in A1 of sheet 1.
Good luck.
Sep 13, 2008 | Microsoft Computers & Internet
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Aug 30, 2008 | Microsoft Excel for PC
22 people viewed this question
Top PRINTER Office Equipment & Supplies Experts
Roger Knight
Roger Knight
Level 1 Expert
R Daniel Wolfe
 Andrew Henderson
Andrew Henderson
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
