Question about The Music
Pitch shift will not open
On the Effects button only the Pitch Bend Control will open, but not Pitch shift..No response when clicked?
Pitch bend issues
Hi, try to find how to reset it or go to default mode,find out in the users manual.Hope it will solve your problem,
Oct 17, 2017 | Akai Ewi4000s Electronic Wind Instrument
I need to know how to raise and lower the pitch
In principle, the primary oscillator needs to be adjusted- some keyboards have a pitch or bend control that if not set correctly, it will affect the tone of the entire piano.
Apr 05, 2012 | Music
The pitch bend of my Korg pa500 Ort just stopped operating properly yesterday, the problem is that "up & down" is functioning normally but "left & right" is not working (no...
The first thing is to verify that it is supposed to work with a particular performance. NOT ALL voices support modulation as well as pitch bend and with an arranger you can turn this feature on and off, usually in the utility functions and then save the setting for each performance/song. Read you user manual about modulation. On page 271 of your manual they show that the joystick is assignable. You have to assign the functions to the effect you want.
Jul 30, 2011 | Korg PA500 61KEy PROFESSIONAL ARRANGER...
Just bought a ps-6 today, tried it through my overall set up the pitch shifter, detuner & super bend are fine, as soon as i use the harmony setting it takes a sweet medium gain lead sound and adds the...
By ading in the harmony signals you are combining 3 signals so gain is probably going to be high you will have to reduce it before it goes to the amp or turn down the input gain of the amp.
NEVER use a pedal in the external effects loop of an amp as the levels are wrong.
Jul 26, 2011 | Roland Boss PS-6 Harmonist Pedal
How can I fix a pitchbend that doesn't work at all on a ROLAND JUNO 2?
Some have found that doing a "Factory Reset" has cured an inoperative pitch bend control.
If that doesn't work, inspect the control for mechanical damage and replace broken parts as needed.
Mar 21, 2011 | Music
Yamaha wx5 out of tune (1 tone to low) and pitch bend wheel working up but not down...
As an electrical engineer, I suspect that one end of the resistance element or the voltage supplied to it is broken. This could be a broken circuit trace on a board or failure of the pitch wheel pot. This is iff the device has a center tapped pot. IF IT DOESN"T (schematics are hard to find on this) then the bias setting for the pitch wheel may be wrong. First thing would be to look if the the wheel has slipped on the control shaft.
Jan 03, 2011 | Yamaha WX5 Midi Wind Controller
Sometimes I face problem with my bendar. If I move it, it changes the pitch. To bring back to normal pitch,I have to move it couple of times. When I try to bend a sound which I used to bend always before,...
It sounds like the knob on the pitch bend control MAY be loose on the shaft or on the mechanism. Since this is a higher value unit, if you are NOT electronically adept, best to take this in for repair... It is probably a simple problem, but opening one of these can damage cables if you are not familiar with the unit.
Jan 03, 2011 | Roland FANTOMG8
How could I set up quarter tone in a precise way, that I could control with bend control of EWI?
Here is a good forum to join: Depending on what you are using for a sound module, I would recommend setting the pitch bend limit or range on the sound module to what you want and controlling that setting with whatever setting you have on the EWI. Read your manuals carefully and you should be able to do it.
Mar 02, 2010 | Akai Ewi4000s Electronic Wind Instrument
Music Logo
14 people viewed this question
Top The Music Experts
Kyle Steven OHare
Kyle Steven OHare
Are you a The Music Expert? Answer questions, earn points and help others
