Question about Pool & Spa
I have a Thermospa hot tub ts702 control panel and it is stuck in sleep mode and the book tells you nuthing about getting it out of it 1how do I get it off sleep mode
  • 37 Answers
SOURCE: How to Get Hot tub off sleep mode
press temp button and then the light button in sequence.
Posted on Dec 10, 2009
thepool
  • 78 Answers
SOURCE: I have LOC on the control panel and I am not able
To Unlock Main Control Panel: Press DISPLAY, MODE, and DOWN buttons within five seconds. The “lock” symbol will disappear. All buttons are now active.
Posted on Apr 23, 2010
adamh294
  • 310 Answers
SOURCE: i have a great lakes
The topside control manuals are paired with the main Spa Pack control system. If you email me the model information off of your spa pack, I can help you to find your manual.
adamh@newconceptchem.com
Posted on Jun 14, 2011
SOURCE: i cant get my hot tub outof sleep mode
Turn Power off for at least 2 minutes. There maybe a battery also to save your setting in the control box, if so unplug. If that does not do it then give us a call we give free tech support. hottubworks.com
Posted on Oct 26, 2012
  • 1631 Answers
SOURCE: I have a density riverspas hot tub and it is stuck
Difficult to answer without knowing the "Brand" of your Spa Support Pak System. Lets presume you have the most common basic pak available - Balboa.
Press "Temp" button and then immediately press "Light". You will then sequence between 3 modes:
  • Economy - may display as Ec
  • Standard - may display as Std or St
  • Sleep - may display as Sl
Should save last setting
Posted on Dec 18, 2012
How do I return my hot tub to factory settings
to get your tub back to Std setting it is a matter of pushing the combination of the mode button if you have one or the temp button along with the jet button or the light button at the same time.
this sequence will go from Std, Economy or sleep mode.
Rod
US Parts Center
Feb 04, 2013 | Pool & Spa
I have a density riverspas hot tub and it is stuck in sleep mode and there for won't heat up how do I take my density riverspas hot tub out of sleep mode
Dec 03, 2012 | Pool & Spa
I cant get my hot tub outof sleep mode
Try turning your GFCI breaker off then back on, may reset the tub's computer. Works on some.
Aug 18, 2012 | Dynasty Leisure Bay Dynasty Spas
Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Nov 27, 2010 | Jacuzzi Pool & Spa
Hot tub stuck in 'SL' mode
Need to know what buttons your topside control has... depending on the model, some have a mode button which you press and release and then immediately press the temp up or down, to select SL for sleep (no heat), ST for standard (heat as needed) or EC for Economy (only heat during filtration). If the mode button is not present, and you have a single temp button and light button, try pressing and releasing temp and then immediately pressing light button, repeat until choice appears, then wait, it will hold last displayed mode.
Jul 09, 2010 | Jacuzzi Balboa R574 System for 1 2 Speed...
My hottub want raise the temp above 89 on the control panel it says sl 89 i know it has three modes sleep mode econo and standard but how do i change the modes? the tub is a nordi sport
Some hot tub keypads have a 'mode' button. If yours doesn't try pressing 'warm/temp' followed by 'Jets'..... it's usually a combination of keys that changes the mode and this one springs to mind but I could be wrong.
Good luck,
Ian, from: http://hottub.synthasite.com
Jun 01, 2010 | Pool & Spa
Nov 14, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
OC hot tub is getting SL error and does not heat. Model is M-09-MOC1545-3. Recently purchased and lost manual. Thanks.
sl means sleep mode and will not heat! try depressing the temp button the either the light button or the jet button usually that will change modes u want st or std mode which means standard. or if u have a mode button try that 1st. or email me a copy of control head to hottubbob2@aol.com for tips! thanks Bob
Oct 17, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Pool & Spa Logo
259 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
