Question about Vacuums
Manual for a Conte ccwv 1800 I bought a second hand vacuum cleaner with out a manual does this model need water in the drum and were do I get filters for this model 05/2013
Model no CCWV 1800 05/2013
  • 625 Answers
SOURCE: Cannot find a filter
In a pinch a discarded flannel pajama sleeve can be employed as a filter on your shop-vac. grab up an end and twist it together and fasten with a piece of wire. the open part slips over the cage of the vacuum and fastens with a large flat rubber band. I'll try to find a source for a filter for you and will get back to you.
Posted on Oct 02, 2007
SOURCE: Need the manual for this vacuum cleaner
Try this link also
Posted on Jun 14, 2008
  • 3 Answers
SOURCE: Need Filter Queen Model 31 owner manual.
Majestic Surface Cleaner Manual
see other post i made for filter queen manual
Posted on Mar 07, 2009
SOURCE: Handi-mate jr. manual
I scanned my manual, but I can't fund any way to attach it here. I can send it to you if you provide your email address.
Posted on May 20, 2009
  • 39 Answers
SOURCE: I need to replace the belt on my Sharp Vacuum
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the can also clean off the debris while doing added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Posted on Jul 05, 2009
Where does hot water go, and cleaner go?
Check your model number.
From the Dirt Devil Website on the right hand side is a User Manual link.
You can also find other user manuals for other models.
May 25, 2010 | Dirt Devil Easy Steamer Upright Wet/Dry...
Cleaning the filters
There are 3 different filters on this particular model. Two of them are foam, and as washable, the 3rd is a HEPA filter that's located on the back and is not washable, but needs to be replaced once a year.
The most important filter, and the one that most people are not even aware of, is located directly underneath of the dirt cup. Directly under the dirt cup you'll see a black tray that says "pull". Pull this tray out, and you'll find a square shaped washable filter. Simply remove this filter and rinse it under water until it's clean. Make sure to let the filter completely air dry before reinstalling it in the vacuum and using the vacuum again.
The second foam filter is located directly above the dirt cup. Remove the dirt cup, and in the clear plastic housing that's directly above the dirt cup you'll find a circular colored plastic piece. Reach your hand up there, and unscrew this plastic part while pulling downward. You'll find a circular shaped filter that wraps around this plastic piece. This filter may also be washed the same way as the square shaped one, again just make sure that the filter is completely dry before using the vacuum again.
The HEPA filter is actually on the back of the vacuum in a grate that pull down to open it and remove it. This filter needs to be replaced only, and can not get wet.
The foam filters can be washed several times, but will sooner or later need to be replaced, as they will start to deteriorate after a few washings.
If you need to purchase these filters, here are direct links to all of the filters on your vacuum cleaner.
Square Shaped Pre-Motor Filter Bissell Part 203-1073
Circular Shaped Bissell Upper Tank Filter 2031085 Pre-filter Lift Off Series
Bissell Style 8 & 14 HEPA Media Post Motor Filter Part 3091
Here's a link to the parts diagram for your model also, this will help you locate the 3 filters.
Also, here's the link to the owners manual for your model as well:
I hope this helps you,
Chris J.
Apr 09, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
Model 1699-1 ProHeat Clearview Plus -water and cleaner do not dispense when using trigger on handle. The turbobrush hand tool works fine.
When it doesn't dispense water an cleaner like that it means that the pump belt needs to be replaced. Here is a link to the belt you nee and the manual:
Bissell ProHeat Belt and Manual
Dec 28, 2009 | Bissell 1699 ProHeat Clear View Upright...
I just bought this vacuum at a second hand store. My girlfriend told me to grab it as it such a quailty product. How ever I can't find a model number or anything else. I need a manual please. Does it take...
I suggest you google what you know. I dont think anyone here can suggest where you can get a manual for a machine you dont even know the name of.
You ask about a bag ... I dont know ... is there one in it now? You ask about a filter, does it look washable?
This 'quality product' is no value if you cant use it, cant get parts for it.
Donate it to the second hand store.
Im sorry to give you this kind of answer.
Oct 05, 2009 | Vacuums
I do not have my users manual and have never vacuumed wet with this vacuum. How do I change it from a dry to wet vacuum. Can't find my manual and I need to use the shop vac for water in basement, do I...
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
May 06, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Need instruction manual
a few steps down in Google, I found the whole manual in adobe format! I only need the filter for vacuuming, so I'm in the clear---except that it won't spurt soapy water out...I just squirt it on with a spray-bottle and use the brush and suction from the cleaner. Sorta fixed the problem but I'm desperate to get on with cleaning this very small area (an RV)
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
1800 vacuum cleaner belt replacement
Generic problem for all Vacuums
How do you get into the belt to replace it?
Not knowing the brand name of the vacuum other than the 1800 vacuum cleaner belt replacement, normally the belt is located @ the bottom the vacuum attached to the brushroll and is held on by either screws, clips, or some even snap on – but mostly they use some type of screws to open the area to replace the belt, if needed contact the company website, include the brand name and the model number and request a schematic of the vacuum and that will give you an exploded view of how the vacuum assm goes together and also shows the belt replacement and how that is connected.
Apr 07, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
