Se borro el QR de la tv Element modelo ELEFW195
    Top Expert:
  • Televison & ... Master
  • 75,404 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
Posted on Dec 04, 2016
kimberlyesco
  • 184 Answers
    Verified Fixya Pro
    SOURCE: Necesito el codigo para sincronizar
    Hola mi nombre es Kimberly Escobar con DISH Network. Con mucho gusto le puedo proveer la informacion que necesita. Ciertos codigos que se pueden integrar al control para que funcione con su television Element serian 627 and 659. el procedimiento a programarlo seria precionar el boton de T.V localisado en la parte de arriva hasta que los demas botones se prendan en rojo, una vez esto suceda ingrese uno de los codigos seguido por el signo de numero por ejemplo 627#. El boton de T.V debera iluminar en rojo 3 veces. Despues de este procedimiento puede intentar usar el control, no le podemos prometer que controle totalmente su T.V. En este link puede encontrar mas codigos y ayuda programando su control http://www.dishnetwork.com/SupportSection/remote-setup. Si necesita mas ayuda o tiene mas preguntas pro favor contactenos directamente al 1800-333-DISH, gracias y espero esto le sirva de ayuda!
    Posted on Feb 15, 2011
    gopakumarg43
    • 75404 Answers
    SOURCE: Saludos necesito los codigos para el control remoto de dish, tv Proscan modelo pld3283d. Agradecida por la ayuda que me pueda dar.
    002,007,000,018,052,011. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
    Posted on Mar 11, 2013
    SOURCE: silvania
    hola necesito ayuda en soporte tecnico
    Posted on May 27, 2013
    • 3698 Answers
    SOURCE: Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
    www.youtube.com/watch?v=xgsliCiVAGA
    Posted on May 19, 2015
    gopakumarg43
    • 75404 Answers
    SOURCE: ayudar con este problemita porfa de una Tv Lg modelo rp-29fd15 cuando la conecto ala electricidad se queda el relay click click y el led de encendido haciendo lo mismo que el relay
    If you wish to get some details; check the site linked here. Pull up older posts.
    http://electro-medical.blogspot.com/
    Posted on Apr 02, 2016
    Se puede conectar este televisor con la frecuencia wf
    Se supone que te refieres a un Control Remoto y luego la pregunta es sobre un televisor de marca y modelo no especificado. Quieres conectar tu TV a WiFi? Es un "smart TV" o sea, tiene tarjeta inal?mbrica?
    Te sugiero buscar en Google con el modelo y marca el manual de usuari de tu TV y las especificacines
    Oct 17, 2015 | Televison & Video
    Necesito programar el control remoto dish modelo 175544 20.0 IR a un tv LG
    Hola, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor comuniquese conmigo a: kimberly.escobar@dish.com
    Kimberly Escobar
    Social Media Representative
    DISH L.L. C
    Aug 26, 2013 | DISH Network IR Remote Control
    Programar control dish con tv element
    Hola, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar.Si necesita ayuda adicional sientase libre de contactarme a: kimberly.escobar@dish.com
    Kimberly Escobar
    DISH L.L.C
    Aug 24, 2013 | DISH Network IR Remote Control
    Codigos de programacion para mi tv tecnomaster
    mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
    Mar 05, 2012 | DISH Network IR Remote Control
    Hola. No se si sirva el Circuito integrado de sonido de mi TV ya que no tiene sonido, pero conectandole un DVD en el auxiliar el sonido es perfecto. Tv broksonic modelo ctgv-4563tct ...
    Hola, posiblemente el circuito integrado donde se realiza la seleccion de audio sea el problema y no el amplificador de audio ya que funciona con el DVD, habria que determinar cual IC realiza esta funcion tomando como referencia la salida demodulada de audio desde la etapa de frecuencia intermedia o adonde convergen todas las entradas de audio del TV.
    Feb 26, 2011 | Broksonic Televison & Video
    Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
    Podrias proporcionar el modelo completo de tu plasma?
    Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
    Sep 12, 2010 | Televison & Video
    NO TENGO EL CD CON LOS DRIVER DE LA PLACA MADRE SE FORMATEO EL EQUIPO
    ¿Sabes el modelo de la placa madre? Si no lo sabes, aún así puedes conseguir los drivers, pero es más fácil con el modelo. Si es una computadora de marca, solo necesitas el modelo y la marca, y bajar los drivers de la pagina web del fabricante.
    Apr 14, 2009 | Computers & Internet
    No funciona
    Ulises,
    A ver si me entendes, el televisor se ha descalibrado con el control remoto.
    o por la tecla que apretaste o por algo que paso.
    Para que funcione nuevamente simplemente debes volverlo a programar.
    Ya se que no anda, y ya se que probaste mil veces.
    Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
    Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
    Los codigos normales del Silvania son 0054, 0030, 0020, 0096
    Si estos numeros no funcionan dame la informacion que te pido abajo
    modelo de tu Sylvania
    modelo de tu y marca Remote
    Oct 19, 2008 | Vehicle Parts & Accessories
    Televison & Video Logo
    43 people viewed this question
    Top Televison & Video Experts
