We have re positioned our t.v .into another room . It is connected to the main aerial. We cannot get any channels. It is saying no signal.
    Top Expert:
  • Televison & ... Master
  • 51,482 Answers
Check the antenna wire .
Posted on Dec 04, 2016
They keep saying signal is weak check your source connection what does that mean
It means exactly what it says, the signal coming to your television is weak. It is usually bad connections in cable, incorrect aerial positioning in over air or satellite signals.
Remove any input plugs, and check that the wires aren't oxidized, that they are shiny and clean.
Feb 24, 2018 | Sharp Televison & Video
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
No tv channels found on autotune . Aerial is in Loft.
To get a 6 way or 4 way signal, it has to be amplified. Does your splitter have a power connection to it. If you just have one lead going into a block and 6 outlets, that is for a high gain signal to go in that is already amplified. You can test by disconnecting all the leads but one. Use the closest set to the loft and use that one to get the sharpest signal by turning the aerial left and right. It has to be in the right direction and if it is off by just two degrees, you will not get a picture. Also aerials and better situated outdoors for the best signal.
Jun 23, 2017 | Televison & Video
Often ABC channels have no signal while all the others are okay.
Guessing you are talking about free to air channels broadcast by terrestrial channels.
I have the same set up , just a normal tv receiving signal through an aerial......Bearing in mind that signals come from different sources , the aerial / antenna needs to be optimally located and positioned.
I often get signals from commercial tv but lose the signal from the BBC here in the UK. I bought and fitted a signal booster and a good aerial and no longer suffer from poor reception on any channel.
Jul 20, 2015 | Televison & Video
Can't pick up channels itv, channel4/5 and itv2 on my bedroom freeview tv and down stairs doesn't pick up film4 and a few others?? I have only recently connected the bedroom aerial to the ariel which was...
hi when fitting an new aerial line you need to put a splitter in the line.
4963215_1-oo4k03phwtyaxld0gomgkgbv-2-0.jpg it looks like this. they say satellite/tv on them this will stop interference from the boosters and the tvs on the same line, you connect it on the main arial line. you can then use both boosters if signal is weak but most digital aerials are good enough without them. it you have the right arial for your area. there are meany sizes. but say you are 15 miles from your tower then use a small aerial has the same fitting as this pic. that is out side aerials, inside aerials ie in loft you need a high gain aerial , long type. hope this helps. also if the aerial is not lined up it will not get great signal there is an app you can use on iphone or androids, tables etc to help you position the aerial in the right place it's called Uk aerial alignment . tool on app shows you the towers in your area and the best ones to use and shows you the aliment to the tower for best results. good luck
Jun 22, 2017 | Samsung LE40R74BDX 40 in. LCD Television
I have a DMR-EZ25EB and sometime after the freeview retune last year I realised I had not retuned. I retuned as per the instructions (and have done so several times since) but I have lost all my freeview...
This is not related to your aerial as you have good reception with your TV. Some receiving units (i.e your DVDr) need the channel memory to be cleared before the re-scan is done. Otherwise the scan gets corrupted.
To resolve this do the following;
1. Remove the aerial from the equipment and leave unplugged.
2. Go to the menu and select rescan or retune. It’ll take a few minutes, but when it’s done, it should say ‘'no channels found’.
3. Disconnect the equipment from the mains power supply and leave it un-plugged for 30secs.
4. Re-connect both the aerial and the mains power supply and switch the equipment back on.
5. Go to menu again and select rescan or retune. You should now have all the channels available to you.
I believe this should resolve the issue for you. If so please do take a moment to accept my solution otherwise it will not credit to my ledger.
Thanks for using FixYa.
Jan 18, 2010 | Panasonic Televison & Video
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
Tv with built-in digital tuner not receiving any channels
Is your outdoor aerial a proper freeview aerial and are you in a strong or weak signal area.You can check here:http://www.stevelarkins.freeuk.com/freeview_digital_tv.htm
Also check your connections as the coax may be shorting with the braid or a bad connection.once checked try ordinary channels on upstairs tv and if ok retune all your digital channels.
This can be due to a few problems.Firstly make sure your aerial is pointing in the right direction as beam aerials attenuate(disregard) signals which are not pointing directly at the aerial.
make sure you are using good quality 75ohm cable i.e rg6 and connections are good and not shorting out.
The length of run of the cable will also affect the signal as will any splitters or joins in the cable.
If you know the signal is good in your area then it will be down to the aerial,cable terminations ,aerial position or a combination of these.
If the signal is poor you can either...Buy a high db gain arial which will amplify the signal and or a masthead preamp which will again boost the signal.
please note that if your aerial is not pointing in the correct direction then any boosting of a bad signal i.e ghosting...will only make it worse.
try starting from aerial direction then connections then a high gain aerial and or booster.
Oct 14, 2009 | Televison & Video
Freeview - No transmitter found
The signal from the communal aerial might be weak, since other people are using it, or it is experiencing interference with a power cable or something.
Try a signal booster from **** Smith or Harvey Norman, RadioShack, Tandy, Walmart etc ( I assume you are Australian - Freeview :) )
OR
Get your own aerial, if you don't live in a concrete shoebox....
Oct 12, 2009 | Televison & Video
Can't get channels 4 and 5, think the problem is with the aerial socket or possibly the cable. The tv works fine in a different room on a different aerial. That aerial is identical to the other one.
If the TV is ok in the other room then the problem lies with your incoming signal. Check your connections. If you are on cable, then it could be a problem with the box. Can you use a scart connection from the box to the TV? If so try to connect up this way & if the problem is still the same then get your box checked.
May 02, 2009 | LG 42LG30 42 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
