Question about Britannia Kitchen Ranges
I have a Britannia dual oven range - I replaced the hinges on the main door - easy, but now I need to change the rollers - looks easy enough, but how do I get the old one out and the new one in?
SOURCE: Belling DB3 Main oven door falling off its hinges
The same thing is happening with my oven. I have found a web page which sells the parts and removing the door and replacing the hinge would be easy enough. The design of the door however, may mean the problem just happens again.
http://www.espares.co.uk/part/cookers-and-hobs/belling/db3/p/1092/154/0/547474/550894/door-hinge.html
Posted on Mar 14, 2008
  • 58 Answers
SOURCE: My Amana gas range's oven door will not stay shut.
they're not too bad, you may need to take apart part of the door to remove the hinges, just remember where everything goes as you take it apart. bring the door to the first stop, then bring the hinge pin locks into place to secure the door hinge lock, then remove door, or just slide the door up. then replace the hinges as needed.
Posted on Jul 09, 2009
  • 8 Answers
SOURCE: selector knob not working
I think you will need and engineer to fix this. Call Britannia on 01253471111. They also have different ervice plans to cover your cooker regardless of its age
Posted on Jul 20, 2009
SOURCE: thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Posted on Oct 13, 2009
SOURCE: Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Posted on Aug 07, 2010
Looking for door hinge 082600712
Lisa, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Oven Parts Appliance Parts from PartSelect
Oven Door Hinge Parts Accessories eBay
Oven Parts Appliance Parts from Easy Appliance Parts
Mar 07, 2016 | Belling FarmHouse 932 Dual Fuel (Electric...
I need some instructions how to change the lower oven element in my britannia SI-12T7 cooker. the element has screws that will not unscrew from inside the oven. any ideas?
straight forward to do. undo the screws to the back panel of the oven.
once remove down at the bottom of the oven you will see where the heater element comes through . there are to main feed wires that are pushed on and one earth wire. pulls these off as they are just push fit.
the element its self is a flat plate with 2 self tapper screws undo these and the element will then come out of the front of the oven. you have to lift it on a slight angle so the feet of the element will come through . hope this helps
Jun 16, 2014 | Britannia SI10T6L Dual Fuel (Electric and...
Britannia si-12t76x2
If your oven has no heat you'll need a new oven element, if your oven is cooking food too quickly/burning at the back then you'll need a new fan, if the oven is burning everything you'll need a new thermostat, if the oven isn't working at all check that the clock/timer hasn't been set for auto ie make sure it is on 'manual cooking'
Jun 16, 2012 | Britannia SI10T6L Dual Fuel (Electric and...
Need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Changing the main hinges on the oven door
Contact the britannia Service team on 01253471111 option 3. Someone there will be able to talk you through or they could do it for you.
Apr 28, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
Mar 25, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Sep 01, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Selector knob not working
Jun 22, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Nov 23, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
52 people viewed this question
Top Britannia Kitchen Ranges Experts
James Gettemy
orangebeast
orangebeast
Level 1 Expert
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
