Question about Vacuums
YV1DZ**********75 Is this a kinitic, momentum or summum volvo??
The brushes are not turning very well. Where can
You can get one here and you can also view the manual with instructuions:
Bissell Momentum Belt
Jan 09, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Bissel Momentum Vacuum
there is dirt in the motor you can take it apart and clean it
Dec 11, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Bissell Momentum roller brush doesn't roll w/ pressure
This is going to sound funny, but check the wheels. Sounds like the pin or shaft that holds them is broke. Also check the tension on your belt. If the tension is to loose then the brush will have a hard time spinning.Good luck
Jul 26, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
