Question about Refrigerators
Fridge door dropped and hard to close. - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 15,351 Answers
Check hinges for looseness or damage
Posted on Dec 04, 2016
    Master:
  • 502 Answers
Yeah that is not good.
How do a fix a Westinghouse fridge door that has dropped slightly
Hinge screws probably loose. Refrigerator doors have hinges screwed on the outside. The hinges allow for you to move door to be level, loosen screws, move door level and hold it there till you tighten screws. Sometimes the hinges are covered with a plastic piece that you pry gently up on to remove.
Jul 03, 2016 | Westinghouse Refrigerators
Whirlpool double door fridge. Door wont stay closed. Have to push extra hard to keep it closed
Take out the shelves and drawers. check the rear is clear of ice before putting them back in place, and ensure they are not stopping the door closing. Next check the top and bottom of the door. Is it hitting the frame when closing? If so, straighten it up by tapping the hinge side of the door to make it square to the frame.
Jul 04, 2015 | Whirlpool Refrigerators
The freezer door is on the bottom and will not stay closed. If i lift up on the door just a little and push hard it will close but will pop open as soon as i let go.
I would check and make sure that the fridge is properly leveled, and also that there is nothing behind the fridge or the freezer compartment that is preventing it from closing properly.
May 25, 2015 | Refrigerators
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
Problem with refrigearator door.Afer opening it,I can not open again resently. I must wait 4-5 minutes to poen the door again. Can you help me ?
If the humidity is high in your area, the humidity you let in the fridge condenses when you close the door and this makes a partial vacuum in the fridge. This vacuum makes it hard to open the door. After a few minutes, the vacuum leaks and pressure inside the fridge goes up and the door is easier to open. This is normal and no rep are is needed. Just pull harder or wait a few minutes to open. If you really are not able to open it and you need to open frequently while cooking, pull the vegetable drawer out a little to prevent the door from closing all the way and sealing. Make sure you close the drawer and door after cooking or you will have a big electric bill. Another option is to slide a spatula along the gasket to allow air int the fridge when you need to open it.
Jul 24, 2011 | Refrigerators
Whenever fridge door is shut hard/ quickly it causes the freezer door to pop open a little...and meltdown the frozen stuff. The fridge door has dropped a bit but I don't think that is it. It seems there...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Nov 30, 2010 | Fisher and Paykel Active Smart E522B...
WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Nov 27, 2009 | Refrigerators
Freezer is working but refrigerator is not
My Maytag (side by side) had a similar problem, turns out to be the damper door. The freezer does the cooling, there's a damper door between the fridge and freezer that opens and closes to control fridge temp. Find the damper door and prop it open. If the fridge temp drops overnight, you'll need a new damper ***'y.
Oct 01, 2009 | Frigidaire Refrigerators
Freezer door hard to close
Any adjustment is at the hinge, you probably find that you have fitted it too close and it is pinching the gasket in the corner. Tilting the fridge back can help, but the doors must be able to swing closed freely first. This can be done by adjusting the footing screws below the front of the fridge.
Mar 23, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
Mar 16, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
