Hola,saludos,por fabor,necesito saber? Como hacer para poder,activar un Dvd en una pantalla super matic,con el control super matic,el Dvd es de otra marca,sanyo,gracias,Xinia
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Posted on Dec 04, 2016
2 Suggested Answers
gopakumarg43
  • 75581 Answers
SOURCE: NECESITO EL CODIGO DE UN TELEVISOR SANYO CON UN CONTROL REMOTO DE JVC
These are the codes for Sanyo TV: 0049 0097 0110 0004 0268 0012 0108 0180
Posted on Aug 19, 2012
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
Jul 30, 2013 | Televison & Video
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
CODIGOS PARA TV GE
HOLA TENGO UN CONTROL REMOTO UNIVERSAL STEREN RM 11 Y MI TELEVISOR ES GENERAL ELECTRIC ALGUIEN SABE QUE CODIGO ES
Mar 08, 2011 | DISH Network IR Remote Control
Mi control de dish no quiere hacer nada quien me ayuda
Hola mi nombre es Kimberly Escobar con DISH Network servicio al cliente. Lamento escuchar que este teniendo un problema con su control de DISH Network, seria un placer asistirle proveyendole informacion que le sea de uso para resulusionar el problema. Si el control no esta haciendo nada primeramente debe asegurarse de que el control este en el modo de SAT significando que cualquier boton que oprima el control el boton de SAT en la parte de arriba se debe encender en rojo. Si ningun boton se enciende en rojo puede intentar poner baterias nuevas en su control, si no funciona significa que el control no sirve necesitaria uno nuevo, si el boton de SAT se prende en rojo puede intentar reprogramar el control a su recibidor. Para hacer esto tiene que accesar la pantalla de System Info en su televisor, puede hacer esto oprimiendo el boton de Sys Info enfrente del recibidor. Despues en el control va a oprimir el boton de SAT hasta que los demas se enciendan rojos cuando vea que se encienden rojos ingrese un numero entre 1-15 seguido por el signo de numero (#) y el boton de record una vez. Trate el control deberis funcionar. Tambien puede entrar a nuestra pagina web http://www.dishnetwork.com/SupportSection/remote-control aqui encuentra ayuda en como arreglar el control y el procedimiento. Si necesita mas ayuda por favor contactenos directamente al 1800-333-DISH gracias espero esto le ayude.
Feb 09, 2011 | DISH Network IR Remote Control
Buen dia no soy una experta con la portatil pero necesito saber como hacer de la manera mas especifica para poder activar el boton lenovo care ya que cambie de windows vista a xp y no se como hacer para...
Hola!
Necesitas instalar el Lenovo Care Pack por Windows XP... Descargalo de aca.
Tambien, te recomendo actualizar el BIOS. Descarga la ultima edicion de aca.
El Rescue and Recovery tambien sera util... Descargalo de aca (version en Espanol).
Suerte y saludos desde Israel,
Pelu.
Feb 05, 2011 | Lenovo ThinkPad SL500 Notebook
Acaban de componer mi camioneta (pontiac montana sv6 1999) porque los buzos hidraulicos estaban pegados y no pasaban aceite (le pusieron nuevos), al siguiente dia de uso empezo a fallar la aguja del...
hola ayuda por favor. tengo una pontiac montana 97 y la falla es que en ocasiones da marcha pero no enciende a la primera. hace como que arranca pero se apaga. pero si acelero un poco al dar marcha si arranca y ya se mantiene normal. que sera. gracias. saludos
Nov 19, 2010 | 1999 Pontiac Montana
Hola , necesito saber si puedo cambiar toda la maquina, excepto el DD y dejar este mismo como master, tengo programas que me costaria mucho conseguir e instalar de nuevo gracias
Muchas Gracias COnstantin, quizas me expresé mal, mira mi problema es que el pc, excepto el disco nos quedó chico, es decir, quiero cambiarlo por una maquina mas nueva core duo por ej, por ende con distinta placa, y el DD tiene toda la informacion y programass con licencia que necesito, entonces necesariamente tiene que quedar como master, me indicaba un tecnico que los driver de la placa podriasn darme problemas, si es así y tengo los drives de la maquina nueva ( placa) no debiera tener problemas?
agradeceré tu respuesta
gracias
Jun 23, 2009 | MSI PM8PM-V Motherboard
Redes virtuales privadas
puedes comprar dos Linksys VPN RV - 42, tienes que tener dos static IP in cada lugar, despues hacer la configuracion, crear el tunnel VPN, los IP internos de las dos redes deben ser distintas, ejemplo: una puede ser : 192.168.0.1 y la otra debe ser 192.168.1.1, despues de bes de connetarlos y hacer las pruebas.
suerte, jajajaja ( si no sabes bien vas a estar dias intetandolo)
Jun 11, 2008 | Computers & Internet
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
