I turn off my Honeywell cm901 thermostat but the radiators remain on
4 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: need to wire a honeywell RTH7400D thermostat to 3 wire hot water
Just mark the old wires on the old thermnostat...R , W etc...and put them on the same terminals on the new 1.....also there should be some adjustment ire : switch on the back or under the cover to adjust for Hot water heating or electric heat...either is the setting you should have it on....also you shouldn't setback the thermostat at night or when away very much....2 degrees is fine , as the boiler will run along time to raise the temperature in the morning and may not get there by the set time
Posted on Oct 26, 2009
FurnaceGuy
  • 74 Answers
SOURCE: I have a Honeywell Chemotherm III. The thermostat
The thermostat may be getting a little old, but I do not think that it is your problem. Look for flash codes on the control board of your heater. This should give a few clues as to what it could be.
Posted on Jan 04, 2010
  • 207 Answers
SOURCE: My Honeywell thermostat is turned right down to 10
sounds like ur tstat needs replacing
Posted on Feb 26, 2010
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Honeywell CM901 - i want to change my thermostat like for like - is it as easy as just replacing and wiring the wires in the same as before?? am i right in saying there is no electricity supply to the...
In some cases yes and Depending on the thermostat some have a 24v power feed. If you have a basic heat only you should only have two wires ( Red White ) unless some one did a home job where the color code is not right.
Oct 18, 2013 | Honeywell Programmable Thermostat Heater
Honeywell cm901
Time to replace unit.
Oct 18, 2013 | Honeywell Heating & Cooling
Hi, we have had honeywell thermostats fitted to all our radiators
turn them all up as high as they can go see if they get hot you may need to bled the air out of them , then see how it goes and turn then back to what is your comfort temp
Mar 21, 2010 | Heating & Cooling
Jan 04, 2010 | Honeywell Programmable Thermostat Heater
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
Central heating
or put it on frost setting if you can take head off spray with a little wd40 around needle and put head back on with head at max then turn down to frost or 0
Mar 01, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
