Question about Irons
Water coming out of steam holes - Irons
  • 27 Answers
Either: the iron is not hot enough to heat the water to steam temperature or the internal water-flow valve is leaking so that too much water is getting through. Check the iron is getting hot enough first. If it is then run some de-scaler (as used in kettles) through the iron to try to clean all the passageways. Always ensure that you fully re-flush the iron after de-scaling or you'll damage your clothes with any acidic residue left in the iron.
Good luck.
Posted on Dec 04, 2016
My steampress 660 is has black stuff coming out
Hi Beverly. The "dried stuff" is scale which occurs naturally in tap water. You should always use DISTILLED water - buy litre bottles (approx.$2.ea Home Brand) all supermarkets. Electricity off, empty out all the water in your iron. Half fill with distilled water, cover the filling hole, and shake water inside iron side to side, up and down, vigorously, empty distilled water out and watch carefully to see if water runs clear or has sediment coming out - may need to repeat this action. When water runs clear re-fill iron as normal with distilled water. Put iron on lowest STEAM setting, LIFT up iron but with soleplate facing down onto an old rag/towel (brown water may come out) press steam button on & off to try & clear the holes. Turn iron off, allow to cool. Thick cloth wipe soleplate over getting into the holes if they have not cleared. Triple wrap a wooden skewer in cloth soaked in white viegar or "scale remover" and circulate it around the blocked holes. Go very carefully do not scratch the coating on the soleplate or holes - very important. Let us all know how this goes please and if I have been of help, do hope so. Good luck, Chris
Feb 12, 2015 | Irons
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Clogged steam holes
If the approved cleaning procedure does not work, your Rowenta iron may have failed.
Jan 09, 2014 | Irons
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
Brown coming through holes and there is a funny odor.
Tell us what water you have been adding to the iron over the years?
Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
Have you ever used Vinegar to try to clean out the chamber?
Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
Mack B
Dec 27, 2010 | Krups V70 Iron
Sole plate leaking
This IS a steam iron? The iron must be hot for the steam to form. If it's not hot enough, the water is leaking thru the steam holes. Also if the channels are calsified (boiler stone has formed into the steam channels) this may happen.
Nov 04, 2009 | Tefal Irons
I have a Black and Decker First Impressions (about 2 yrs old). When on steam it always spits out large puddles of water on the clothes as I'm ironing. It seems to come from the top or bottom part of the...
It's a possibility that you iron steam making elements are caked with lime and possibly the steam holes as well.
Purchase some "Lime Away" and dilute it 50/50 and pour it into your steam iron (drain all the old water out first and leave the iron unpluged) let sit for an hour or so and drain out, fill it again with clear water shake and drain out do this a couple of time then turn on the steam and see if it works properly, use the first time on an old towel to be sure all the chemical has been rinced out. Good Luck.
Feb 28, 2009 | Black & Decker D2030 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Irons Logo
70 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
