Question about Sanyo DVW-7200 DVD/VCR
DVD won't work
I tried to watch a DVD and all I got was sound - no picture.
    Master:
    Sergeant:
  • 226 Answers
Check your connections opn the back of the dvd it sounds like the input is plugged into the wrong port
Posted on Jul 20, 2009
Sound okay on tv but no sound on bluray player
Make sure the audio inputs are on the same input as the video cable.
Dec 29, 2014 | Audio Players & Recorders
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Samsung hdtv, I have sound but no picture. This is an older tv, I have had it for about 6 years.
Have you try watching using a DVD player on your t.v if doesn't try watch on it using a DVD player but if still it doesn't have a picture but only sound perhaps there is a problem with your HDTV.
Jul 01, 2011 | Samsung PCL5415R TV
The HDM1 on the DVD player model DVP3962/37 has no signal. The player has been working for a year with no problem. We can only watch the DVD on component 1 which is not in color.
The HDMI should work hooked directly to tv through An HDMI input but if it doesn't, try either watching yourself or have someone watching while you twist and try to push all three(blue, green ,red) connectors into their in/out jacks. I feel composite gives you better picture anyway> the HDMI is just easier because it carries sound and audio. Anyway, one of your jacks is probably not in all the way>
Apr 04, 2011 | Philips DVP3980 1080P DVD PLAYER
No picture while watching DVD but sound works
make sure the dvd player is not in progressive scan mode
Apr 13, 2010 | Toshiba 14DLV75 14 in. TV/DVD Combo
Sound but no picture. Not progressive scan issue I think.
Have you tried swapping the scart lead ends around, this might work.
Mar 23, 2010 | Zenith DVT412 System
Dish menu but no picture or sound
Try holding the power button in on the receiver until the picture goes away then turn it aloose it will reboot and your sound will usually come back. If you had rather and can get to it unplugging it from the electric outlet, the receiver, does the same thing.
Oct 21, 2009 | Televison & Video
LAPTOP DVD DRIVE WONT PLAY DVDS
ok " get a CD/ DVD cleaning disk , you pop that in and it will clean the lens inside, and they don't cost much, but do so much
good. happy movie watching
Jan 22, 2008 | Acer Aspire 5610-4648 Notebook
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Was watching TV and now Black with White Lines
I call a tech in. It could be quite a few issues.
May 14, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
186 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
