Video Game Consoles & Games Logo
Posted on Jul 20, 2009
I streamed my mp3 or media to xbox 360 and i don't have media center becuz we arent rich -.- i have basic and i have media 11 most of my music shows up on my 360 but when i try playing the music file it says it doesn't support the file and gives me a status code 19-04-80004004 what do i do?
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jul 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
5110
Points
16
7helpful
Status code 04-8007065b for xbox 360
Dude, you probably have the xbox blocked in your PC's sharing options. Just go to: Control Panel>Network and Internet>Homegroup>choose media streaming options.Your xbox should appear on the list of devices on your connection. simple allow it.
That was my solution to this error at least...later.
tip
Play videos on Xbox 360 and stream videos to Xbox 360
How to play videos on Xbox 360 and stream videos to Xbox 360 – including Blu-ray, DVD movies, and videos in various file formats
This tutorial intends to list out all the video formats supported by the Xbox 360, and explains all the available ways to play videos on Xbox 360 in HD quality or stream videos to Xbox 360. The videos include Blu-ray movies, standard DVD movies, and various other videos, such as ISO image file, Camera footages, MKV, MTS, VOB, M2TS, TS, TP, FLV files, etc.
Let's Get Started.
Part 1: The details of Xbox 360 supported file formats
1. AVI:
File Extensions: .avi, .divx
Containers: AVI
Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps.
Audio Profiles: Dolby Digital 2 channel and 5.1 channel, MP3
Audio Max Bitrate: No restrictions.
2. H.264:
File Extensions: .mp4, .m4v, mp4v, .mov
Containers: MPEG-4, QuickTime
Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. Audio Profiles: 2 channel AAC low complexity (LC)
3. MPEG-4:
File Extensions: .mp4, .m4v, .mp4v, .mov
Video Profiles: Simple & Advanced Simple Profile
4. WMV:
File Extensions: .wmv
Container: asf
Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps.
Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
Notes: You can not mix and match the video and audio codec outside of the above defined lists randomly.
Part 2: Different ways to play videos on Xbox 360
With regard to playback videos from a USB storage device, please note that the Xbox 360 will support as big of a storage device as you can format using FAT32, and the maximum size of any single file on FAT32 is 4GB. Besides that, the maximum file size for an AVI, MPEG-4 Part 2, and H.264 file that can be played is 4 GB as well. To play a file greater than 4GB on Xbox 360, you can use Windows Media Player 11 and the Zune software to stream videos from your PC to Xbox 360 console, and notice that the file format must be WMV only. Why is it so special with a WMV file? That maybe WMV is a codec developed by Microsoft.
Well, that is to say, to some extent, we can consider WMV as the optimal format to play or stream to Xbox 360. When you are gonna watch a Blu-ray/DVD movie, or an MKV video, or some files else that are out of the range of Xbox 360 workable formats, what is your solution? We usually make use of Pavtube Blu-ray Video Converter Ultimate to do format conversion. Why do we choose it? Mainly because of its splendid output quality and its feature of an all-in-one application: a Blu-ray ripper, a DVD ripper, and a versatile video converter.
Part 3: How to convert Blu-ray/DVD and videos to WMV for play/stream on/to Xbox 360
We have mentioned in the above contents that the program we will use is Pavtube Blu-ray Video Converter Ultimate. Go to find a step-by-step instruction from the following part.
STEP 1: Load Blu-ray, DVD or other video files into this program
Click "Add Video" to import video files, and click "Load DVD" to import Blu-ray or DVD files.
STEP 2: Select subtitle and audio track
Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track as your choice. Your selection can be reviewed in the preview window to the right hand of the main interface.
STEP 3: Select WMV as output format for Xbox 360
Click on the drop-down list at the opposite side of "Format", and then choose "WMV3 (WMV9) (*.wmv)" as output format.
STEP 4: Do optimal settings for the output WMV files
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the popup window. To make it excellent for playback on Xbox 360, you can follow the optimal settings as below:
Video codec: wmv3 (the default one)
Resolution: 1920*1080
Bitrate: 150 kbps
Frame rate: 30 fps
Audio codec: wmav3 (the default one)
Sample rate: 48 khz
Bitrate: 320 kbps
Channels: 5.1 Channels
Do remember clicking "OK" button to confirm your settings.
STEP 5: Click "Convert" button to start BD/DVD ripping or video conversion
Once finished, click "Open" button at the bottom to get the output WMV files for Xbox 360, which now is prepared for playback or streaming.
Part 4: How to stream videos to Xbox 360
Well, as we have mentioned in Part 2, there are at least four ways to stream videos to Xbox 360, from Windows Media Center, Windows Home Server, Windows Media Player 11, and Zune Software. Actually, lots of online articles have detailed the setups and operating steps, just check the following links to find the one which is most suitable for you:
How to stream videos to Xbox 360 via Windows Media Center
How to stream videos to Xbox 360 via Windows Home Server
How to stream videos to Xbox 360 via Windows Media Player 11
How to stream videos to Xbox 360 via Zune Software
Can i get windows media center without a pc?
No, unfortunately, you need windows media center on your pc to stream videos, music, and pictures from your pc to your Xbox. It kind of sucks I know, as windows media center isn't the most accurate of programs. Has a tendency to loose data. Also, since it is a windows platform, your Xbox will have issues playing certain types of media files. Hope this helps.
How to stream video through xbox
on the dash board go to media center
write down the 4 digit number and log onto the site it tells you
enter in the number
you will use the media center to look at pics listen to music or watch movies off any windows pc on the network in your house. If you have multiple computers in the house you can access them all with the media center extender.(your 360) it streams all this over your network. sometimes this can be a problem due to lagging. I bought a Western Digital 1terabyte (1000GB) my passport external hard drive and formatted it to FAT32 and backed up all of my music and movies off my computer to it. the external hdd runs off of a usb and doesn't need to be plugged into the wall so I can take it any where. it is a little bigger than my iphone. it works on my 360 and ps3 great. if you have xbox live download the "optional media update" from the marketplace for free to be able to play more types of video formats. you don't need a gold subscription to do this
How do i get windows media to work on my xbox
To use your Xbox360 as a Media Center Extender, you must "link" the Xbox to your Media Center PC. Follow these instructions:
http://support.xbox.com/support/en/us/nxe/xboxlive/troubleshooting/networkhelp_mcxpc.aspx
This should only need to be done once. If you just want to stream music/movies from your PC, it should be auto-detected by the Xbox as long as it's on the same network. Make sure you have the latest version of Windows Media Player (version 11).
I wanna use a phone line to get the internet and the music off my laptop to connect to my xbox 360...?
Phone line? As in dial up? No dice. You need, atleast, a DSL connection or faster to get Xbox live.
You can use a UPnP media server, such as TVersity to stream music from your laptop to the 360. What's cool about TVersity is that even though the music you want to play is an unsupported format for your Xbox, it will automatically transcode (make it into something the Xbox 360 can play).
If you have a broadband connection (e.g. DSL, Cable, Sat, etc.) you can have Tversity stream your favorite internet radio stream to your Xbox 360.
Download the latest Windows Media Player, Tversity or These other media servers, install, configure (TVersity is fairly easy to setup), and go look for the Tversity folder in your Music section in the NXE menu.
I wrote a how-to on setting up TVersity here if you need help setting it up.
Hope this helps,
Bill
Live from pc to xbox
Thats not connecting to xbox live. thats MEDIA CENTER. Streaming music,videos from your PC to your 360.. Evolution!
Can not connect xbox to vista basic laptop (using an ethernet cable to connect console to pc) (pc is on wireless internet), have set media sharing on in Windows Media Player. Vista Basic does noy have...
If it doesnt have media center, just right click and share any folders you want to stream through your xbox.
Also might be useful to open file and media sharing in network settings.
2helpful
2answers
Xbox 360 Not Playing Music Through External Hard Drive
In windows media player 11, click on the small down arrow below library and select media sharing. Check the box for share my media then turn on you console. I dialog box will pop up asking you to approve file sharing. You can then customize your options for that device. If the dialog box dose not pop up you have a firewall problem. For the Iomega Media Drive, you have to use the software that came with it. Open the program click on configure, select the folders icon, and look next to your media folders and make sure DLNA is on otherwise your console cannot access those folders.
1helpful
How can i save music to xbox360
you cant save music from your mp3 player to your xbox but you can put the music onto a cd and do it that way. Or you can hook up your xbox to you windows pc media center but burning the music you want to a cd and then saving it on your xbox will be easier.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
