Model EDI97170W code error E20 appear on the LCD panel.. is means for
  • 1,924 Answers
An Electrolux?
The E20 fault code means there is a blockage in the drainage system of the machine.
Check the drain hose, the laundry sink tub and also the pump filter at the bottom right hand side of the washing machine on the front of the cabinet. Pry the door open, undo the filter bung and clean out the pump housing ok,
One of these is blocked and it is restricting the flow of water when the machine should be fully drained before spinning.
Posted on Dec 04, 2016
    Top Expert:
  • Washing Mach... Master
  • 50,270 Answers
Search error codes thru Google by maker
SOURCE: washing machine error code on Frigidaire ATF6000E
thank you larkinator.. that totally fixed the problem as far as i can see right now, I am letting it "wash" a load of nothing. it was a bunch of BS how they hid the filter... I had to literally take apart my whole machine. :-) but its fixed, THANKS!!!!!
Posted on May 28, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
  • 208 Answers
SOURCE: I have a code E20
bad pump
Posted on Jun 22, 2009
rdrsp
  • 85 Answers
SOURCE: What does the error code E20 mean please
E20/21: THERMISTOR resistance drifted out of range (faulty), or ambient temperature below freezing.
Posted on Oct 25, 2009
  • 1937 Answers
SOURCE: where do you get what the washer error codes mean
Please see the following:
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0407366.pdf
Posted on Nov 08, 2009
Testimonial: "thanks for the help oldguy5"
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Error codes E20
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Nov 27, 2010 | Washing Machines
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code e20 model # gltf2940ee0
Hi
Daniel
Jul 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E20 ERROR CODE
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Jun 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
