Question about Exercise & Fitness
I AM HAVING THE PROBLEM CAN INTERCONNECT FAILURE PLEASE GIVE ME RIGHT SOLUTION AND I HAD CHECKED THE FUSE IS OK AND CABLE ALSO OK THEN WHAT IS THE PROBLEM
    Top Expert:
  • Exercise & F... Master
  • 52,086 Answers
SHOUTING here gets no results
Posted on Dec 04, 2016
Won't power on!
You may need an electrician or tech to look at this as you will probably need special tools. If you have a multimeter, check the interconnect cable - the cable that connects the indoor to the outdoor and allows it to communicate. Check that they are connected correctly and to the right terminals. Check the voltages - supply and signal. Set your meter to DC Volts, test between terminals 2 and 3, of the outdoor unit and wiring terminals. You
should see 0-65 V dc, it will be fluctuating.
If the Voltage is not present disconnect the inter unit wiring, test the Voltage on the wiring terminals again, If
No Voltage is present, the outdoor PCB must be faulty.
May 05, 2015 | LG Heating & Cooling
Upper PCA problem
Please RUN the software calibration for eady diagnostic and fix it. God bless you
However follow this steps and fix it. God bless you
Probable Cause 1. A failure in the upper PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the input voltage to the upper PCA to be too low. Corrective Action
  1. If the error message is continually displayed when the unit is powered up, the upper PCA needs replaced.
    External causes may make the error appear intermittently.
    1. If the AC input of the unit dips significantly during power up test sequences, the test could fail causing the error to appear.
    2. A treadmill connected to a non-dedicated AC circuit can experience this error intermittently.
  2. Determine if the interconnect cable is the cause by substituting a know good cable in place of the current cable. For test purposes, the substitute cable needs to be connected directly between the upper and lower PCA's, without routing the cable internally.
Nov 22, 2013 | Precor 9.27 Treadmill
Precor error 12
Precor Error 12, Watchdog (Lower PCA) Probable Cause 1. A failure in the lower PCA overloads the low voltage power supply and causes it to drop below the preset level.
2. A fault in the interconnect cable (upper PCA to lower PCA) causing the low voltage power supply of the lower PCA to be too low.
3. A failure in the upper PCA that overloads the lower PCA low voltage power supply causing it to be too low.
Corrective Action
  3. Determine if the upper PCA is the cause by substituting a know good upper PCA for the existing upper PCA.
Precor Error Code 12 12 Watchdog Lower PCA
May 04, 2013 | Precor EFX 546i Elliptical Version 4
Error 30 shows when i press quick start??
Any 30 series error code means that their is no communication between upper and lower boards. The main Telco harness ( looks like a telephone or DSL wire) my have a bad or broken connection. Unplug unit and taken motor shroud off and check connections should be able to plug and unplug same goes with upper console. If this does not help then either call a local service provider or call Precor directly give them the Model# and Serial# for this unit. They should provide you with the additional info needed
Good Luck!!
MAX
May 04, 2011 | Precor C954i Commercial Treadmill
Draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
Apr 07, 2009 | JRC 1000 MKII Radar GPS Receiver
I don't have a sound
please confirm---first power on----speaker button pressed(if you have one)-no mute button pressed--you select the right input source-input interconnect cable is ok.-----------setup of speaker is ok.your output cables to speakers are ok.
Jul 24, 2008 | Audio Players & Recorders
Power failure.
Try to check first your power cord,
Probably theres a cut on wire that give the flows of electricity
Nov 26, 2007 | JVC MX-D402T Shelf System
Give me hints
head cleaning is enough. and or guide alignment may need. contact a professional service technician.
Nov 25, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Exercise & Fitness Logo
1,286 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
