Question about Refrigerators
Key maker was frozen. tried unplug it and plug it back... now it won't even turn on
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
Posted on Feb 18, 2008
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
dunnbiker
  • 8546 Answers
SOURCE: Can't get the stereo out
It's in the manual, page 24.
DEMO
Press EQ master on the front panel in power off state to demonstrate the function in the display window. To
cancel it, press POWER or EQ master again.
Posted on May 29, 2011
  • 697 Answers
SOURCE: My register is frozen and I unplugged it even and it won't work.. what should I do?
If it's still unplugged, which you did even, according to what you wrote, plug it back in...this step is important.
Posted on May 13, 2012
SD Tech
  • 14553 Answers
SOURCE: Coby HDTV Model TFTV 3227 Won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_14_2012_1_18_09_pm.jpg
Posted on May 14, 2012
Frigidaire ice maker
My Samsung would freeze up periodically especially when I didn't change the filter. Contaminants will cause frost or freezing in the line. The result was a tiny frozen blockage near the solenoid.
UNPLUG the fridge and run a hair dryer directed at the ice maker. Being careful to not allow plastic parts to overheat.
Sometimes you may even hear the tiniest crack when it lets loose. probably only take 20 minutes or so. depending how much of line is frozen.
Oct 28, 2017 | Refrigerators
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
May 12, 2012 | Computers & Internet
How to troubleshoot ice maker for my GE refrigerator
The first thing to check is the temperature in the freezer. Even though everything is frozen the ice maker won't cycle unless its below 10 degrees F as a safety precaution. If the temperature is good, and since you can't manually advanve the ice maker, or not suppose to anyway what I would do is turn the ice maker off a few minutes and then turn it back on, but when you do pay close attention to the fill tube where the water comes in at, because if the valve is good, a little water should flow up real quickly. If this happens, change the icemaker.
May 10, 2012 | GE GSL25JFPBS Side by Side Refrigerator
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
My dreammaker spa has power and lights but the pump won,t turn on.it makes a sound for a few seconds like it is trying to turn over then it stops.it was recently running .
Sounds like the pump is jammed or the motor bearings are frozen. If you can take it apart, try the pump first. The bearings on modern motors are pretty reliable. Get everything cleaned and lubed and put it back together. Good luck...Lee
Jan 14, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
The ice maker was turned off for a few weeks and when I turned it back on, the water wouldn't feed the tray. So no ice. I put some water into it manually and it made the ice dropped it into the bucket but...
Have you checked to see if the water inlet inside the freezer compartment at the ice maker is frozen? This is pretty common.
You can thaw it out with a hair dryer (carefully), then cycle the arm, wait for a little while and see if the ice tray fills.
Next thing to check would be the water line and fill valve, but try the above first.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a MBF2556HEW Fridge. Various fresh & liquid items in my fridge are freezing. I've turned the temp down to 3 from 6, and it's still doing it. The fridge also makes a clicking sound every few...
Try unplugging fridge for a few minutes then plug back in,if it still does it you could have a relay going out? Also if you have another freezer put frozen items in it and refrigerated items in another fridge unplug othernight then plug back it it could be froze up also when unplugged clean coils with brush and vaccum either underneath or on back,most likely underneath(becarful not to bend anything and make sur unplugged)Try all these tactics before you start changing parts!!!!Best of Luck to You!!!amtnng
Aug 12, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
I have a whirlpool gold refrigderator model# GS6NBEXRL00 and the ice maker is not producing any water. I replaced the whole ice maker and nothing happened. After unpluging and plugging the fridge back in...
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Mar 06, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker stopped working
maybe the valve letting the water in to the ice making part has failed
or a thermostat issue
Apr 29, 2017 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
