SOURCE: LG chocolate phone/low battery/plugged in/constant beeps
take your battery out & rub on the pins of battery. then put it in the cell phone & switch it on & charge it.
SOURCE: clock, power locks, power windows and radio not working
for the check engine light you will have to borrow a OBD2 code scanner from your local auto parts store and find out what the code is. although it may be related to: for your electrical problem there is a blown 10 or 15 amp fuse. just check your fuse box for one that is blown. there may be more than one. replace with same-amperage fuse and see if it happens again.
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
SOURCE: Starlite NextPlay Ipod docking alarm clock radio
GO TO WALMART OR SOMEWERE AND BUY A NEW IPOD DOCK.
SOURCE: Need instructions for settings for alarm clock radio model cr106r
Hi Dorothy, The link below is a FREE 2 page user manual for Tesco cr106r.......................CHEERS..
https://ttselectrical.custhelp.com/ci/fattach/get/417837/1442080704/redirect/1/session/L2F2LzEvdGltZS8xNDYyMjMyNzM5L3NpZC8qUFJGRHdQbQ==/filename/CR106R_EN_IB_V1.3.pdf
