Question about Gestetner Office Equipment & Supplies
Error code E-01 for gestetner dx 2430 - Gestetner Office Equipment & Supplies
    New Friend:
I m gatting a E-00 error code geststner dx2430
Posted on Nov 05, 2017
3 Suggested Answers
NALDZ
  • 38 Answers
SOURCE: Service Code
TRY CLOSE ALL THE COVER PROPERLY
Posted on May 12, 2008
  • 3 Answers
SOURCE: I'm getting a e7 error code on the Gestetner 2732ztd
This means a probem with the sorter, check sensor's and jogger
Posted on Mar 18, 2012
Model DX2430 printer. What does E-12 error mean?
E-12 Pressure Plate error
See if the springs( C252 3556 Spring:Pressure:Master Ejection:13.98N)is still attached on both sides of the pressure plate.
Ricoh DX 2330 2430 3343 Service Repair Manual
Jan 23, 2016 | Office Equipment & Supplies
H2-01
"Press # - Interrupt - C - Interrupt -14 - Start key Thermistor open
The thermistor is open. The fusing unit is not installed.
Dec 02, 2013 | Sharp Dx-C311 Copier
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
What does the error code E 01 stand for?risograph 4050
If its CR or TR, E-01 is main motor lock. turn off machine and hold reset button in while you turn the machine on again. Make sure your master removal unit and master feed unit are closed corectly.
Apr 07, 2009 | Riso RZ220 Duplicator
Service Code
Mar 18, 2008 | Office Equipment & Supplies
Copier problems
What model gestetner is it? There are different ways to rest it. What generation are you talking about? 10 years old or two days old model?? Need some more info. The problem may just needs to be rest, it most likely a fuser code to cold or to hot.
Mar 10, 2008 | Office Equipment & Supplies
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
328 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
