Question about Alpine Car Audio & Video
Need to know how to wire up an Alpine 3531 car amp
SOURCE: Alpine Cdm- 7834 wiring help
bypass amp and run new wires to all speakers ,,,, will sound better .
Posted on Jun 17, 2008
j_del
  • 1586 Answers
SOURCE: Need to know how to
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Posted on Aug 03, 2008
  • 4 Answers
SOURCE: 3 amps 2 subs sound system for car, need wiring help
it is easy to hook it up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jan 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: Wiring alpine amp and sub
To wire your 4 ohm dual voicecoil to a 2 ohm mono load - all positives to + on amp.... all negatives to - on amp.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 29, 2009
  • 16 Answers
SOURCE: I have a 1998 Toyota Camry...Trying to hook up an
From what I can tell you cut the wires to your factory wiring harness and that is what you want to hook up to. My advice is to reconnect the factory harness and buy the adapter harness for your car and use that to hook up to the alpine it will save you hours and possibly your sanity. If you want to hook up directly to your car without the adapter you will need to figure out what wires are the power ignition and ground with a multimeter or power light. Easiest way to find ground is to just put in a ground wire with in a foot or so from the deck. Then it's just a guess and check for the correct placement of power. I suggest turning the power placement on the deck to what speaker you want and repeat for all speakers until your finished. Or you can buy a Chiltons or Haynes manual the should have a wiring diagram
Posted on Sep 03, 2014
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Dec 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
I just picked up a 12" type r in a box with a alpine m 350 how do I know what kind of type R I have without taking it out of the box?? and how do i hook it up to this amp??
Not to insult you in any way but u need to know how to wire into car's electrical system at the battery then to a fuse then to the amp and then output the signal from the deck to the amp.. finally to the subwoofer. you need to hook up 12V constant battery power , then remote from the deck ,ground wire from amp to chasis for power.. then wire to sub.
Sep 10, 2009 | Alpine SWR-1222D 12" Type-R Series...
Alpine sub pre outs
i know people dont like doing it this way but when in doubt, splice wires.
go to walmart and buy a crossover, splice your front or rear door speaker wire and wire in the crossover and also the door speaker. plug your RCA cables in and run them back to the amp.
most people with stock decks do this if they dont have sub out or amp out.
if u need more help let me know
Feb 18, 2009 | Alpine IVA-D310 Car DVD Player
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
Aug 02, 2008 | Alpine Car Audio & Video
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
Subwoofer
what OHM is the voice and what OHM can you amp Handel?
This are the facter that you need to know but the esey to do it is + to + and to the + on the amp and the - to - and to the - on the amp and this should give you a Two OHM ratting and will giv you Two time the Power out of your amp?
If you need more help E-Mail me at Gennisthgreat2000@yahoo.com
Oct 24, 2007 | Alpine SWR-1542D Car Subwoofer
Alpine amp and subs questions
it will depend on how you use the 2 alpine subs,, do you know what there individual impedance is [ ohms ] and how you intend on wiring them,,,in series, in parallel, in any case you must maintain the min load in order to load the amplifier properly,,,otherwise the amplifier will operate improperly and allow DC [ direct current ] to pass and fry your subs...so what I really need is more in formation
Jul 15, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Car Audio & Video Logo
106 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
