Question about Thomson RCA DCM245R Modem
Comcast internet have a rca dhg 535 modem can i get internet with this
  • 4,806 Answers
Yes you can get the internet with that modem but only through a cable connection.
Here is the specs on that particular model for your information >>>>>>>>>>
http://www.newwavecom.com/phone/pdfs/DS_DHG535_200802.pdf
Regards.
Posted on Jul 20, 2009
RCA DHG 535-2 Cable/telephone modem installed by Comcast. It is beeping about every 10 seconds. All front light are solid green except "link" which is flashing. How can I stop the beeping?
Have you contacted Comcast about this?
Since they installed it, it is more than likey their equipment. Give them a call on their support line. Their support people will be able to remote in and check that box.
Nov 07, 2010 | Computers & Internet
Comcast is my service provider and I have had an RCA DCM 245R modem for almost 10 years. Until recently it has worked fine. On an ever increasing basis I am losing internet connection and when I look at...
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
Aug 15, 2010 | Thomson RCA DCM245R Modem
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
RCA Thomson digital cable modem internet light is flashing and no connectivity. Is it the modem or the internet service? Comcast was less than helpful...
looking at the internal modem page.usually:192.168.100.1. on your browser.explorer works best for this look up. you dont need internet access for this. once inside you can look at signal strength coming from the street and signal going back. if its out of spec.then that needs to be corrected. Note :call your provider and ask for down/up stream
specifications. also weather or not your modem is ( EOL) End of life.
Good Luck.
Mar 27, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
When connect the power I get all solid lights except for the Internet light. Reset does nothing. I got the Modem on Ebay from a past Comcast user. Any ideas? Is it a goner? Thanks... Darryl From Portland...
You have to notify comcast, to let them know you bought a new modem. Comcast uses a two way communications to all of there devices, and it is not setup on your new modem.
Dec 06, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
New modem will not work with my Belkin F5D7230-4 router
I would start by re-setting the modem. Disconnect the power for the router and modem. Wait a minute or two. Plug the modem back in first. Wait for the modem to complete communication with your internet service provider. When all communication lights are good on the modem then plug the power into the router. It amy take a few minutes to get all the lights. Hopefully this will allow the DHCP to release from the old router and renew to the new one. Make sure if your internet provider requires any manual configurations that they are properly configured in the new router.
Sep 12, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Thomson rca cable modem dhg 535-2
Here is the usb driver it is directly from the disc for the Thompson 535-2 cable/voice modem. I know this is not on the internet anywhere so please share.
http://rapidshare.com/files/303844631/RCAThompson535usbdriver.rar.html
Jun 24, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Cant use 2 laptops at same time
you need a router to connect 2 pc to one modem at the same time
Jun 15, 2009 | RCA DCW615R Wireless/Cable Modem
DHG535-2 and LAN switch issue
It sounds like the LInksys that they replaced was also a router. A router will route packets to multiple pc's that are connected to it. The cable modem just sees the router as 1 pc. When you use a switch, the cable modem will see all of your PC's. and Comcast just allows 1 pc. You will need to buy a router to use more than 1 PC which will be cheaper than using Comcasts Home Networking service which will network up to 4 pcs
May 29, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Can't connect to the Internet via router
Well, this is a very generalized problem that others have, so i'll give you some starting tips. If you can connect when you plug your computer directly into the modem, then it sounds like your modem is bonding to your computer. There are a couple ways to fix this. The easiest is to ask your router to clone your MAC addess (not to be confused with a mac computer, a MAC address is a 10 digit code that uniquely identifies your computer on a network). See the attached image to find where it should be. c26d492.jpg
Once you set it to clone your machines mac address, unplug the computer from the modem, and plug in the router. If this doesn't fix it, please comment back and we'll try some other things. If it does, then give a good rating :-)
Steven
Aug 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Thomson RCA DCM245R Modem Logo
780 people viewed this question
Top Thomson Computers & Internet Experts
jimmy Leo
Raj Patel
Wbix
Are you a Thomson Computer and Internet Expert? Answer questions, earn points and help others
