Question about Vacuums
We have abissell pro heat and it wont spray water what do i need too thx
SOURCE: I have a Bissell pro heat carpet cleaner, the
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Posted on Mar 01, 2009
SOURCE: bissel pro heat 2x wont spray any water
I had the exact same problem with my ProHeat 2. It would spray only through the hose attachment but not on the floor. Cleaning of the spray endings on the floor unit fixed my problem. Either soap deposits or dirt was clogging the spray endings. Here is what to do to clean up the spray endings:
1. Remove the water container from the bottom unit
2. Look up for two red plastic endings on the bottom unit
3. Using your fingers to clip sides of an ending, carefully remove it from its slot
4. Using pliers, release the clamp from plastic ending and remove the red plastic ending from the hose
5. Clean the ending
6. Put the ending back on the hose, slide clamp back on the ending
7. Insert the ending back in its slot
8. Repeat 3-7 for the other ending
That solved the problem for me!
Posted on May 17, 2009
SOURCE: My brand new Bissel pro heat allrounder wont spray
I would suggest RETURN it while still in warranty ! We were too bussy living, did not use machine while still in warranty - and now we are stuck. Same problem as yours.
Posted on Jul 16, 2009
SOURCE: bissell pro heat - belts are ok. water will not
Remove the handle, disassemble the lower section of the top to get to the heater. Make sure the unit is unplugged! Use miniature bottle brushes like the painters use to clean paint sprayers (I purchased mine from Harbor Freight for about $4) and clean out the ports. Also check the valve that the trigger opens. It is located just above the heater.
Posted on Feb 17, 2010
Testimonial: "Thanks for the advice. Sure enough, one of the hose ports was clogged. This saved me at least $85. "
  • 20 Answers
SOURCE: The water in my bissel pro 2X heat will not spray
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
Posted on May 06, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
I have a bissel pro heat 2x and it wont spray
I love these and have 2 of them! The warrantees are usually good and it is your pump if both the hand held and carpet positions won't spray water. Both the soap tank and water resevoir need to have at the very least water in both for the unit to work. Yes... You can use just hot water for light cleaning in both. The pump controls both the spraying water and suction. Last, if one or the other won't spray, the unit can have residue blockage. The passages are narrow, check to see if they are clean. Last test. Turn it on, release the handle. At the base of the neck there will be an oval shaped opening. With the handle on the floor as if filling the unit with water...put either your hand or a paper plate over the hole to see if there is suction. If the pump is good, you will feel a lot of suction against your hand or the flat surface of the plate.
Sep 05, 2011 | Bissell Vacuums
Bissell pro heat not spraying water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 06, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My brand new Bissel pro heat allrounder wont spray any water out?
Jul 16, 2009 | Vacuums
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Thankyou,
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
